timing belt replacment!!!
TheGTkidsGSX
11-21-2003, 11:54 PM
Alright i baught this 1991 GSX and the water pump was leaking so i ordered a new pump and timing belt kit.
i replaced the new things and i had it running int he garage and after about a minute of running it developed a bit if a pingy tap, nothing load but just noticable under load or when reved from idle, so now today i pull it out and after moving the car the noise is loder and the car it misfireing, so i shut it down and about a 1/2 hour later i go to start it and its a load ass fast clanking noise! like its constant not like a bang so i shut it down and pushnit back in the shop and pulled the valve cover off and checked for somthing loose in there but it was fine now i have the vlave cover back on with about 5 bolts and it won't start it turns over fine no noise or anything but it won't fire the plugs are wet but ok and it seems to have spark and fuel so what could be the problem?? it ran fine for about a good half hour the other day and now it dosn't eun at all!! help!!
kjewer1
11-22-2003, 09:28 AM
Did you at least use the page at www.vfaq.com when doing the timing belt? A bad tbelt job is the number one reason for dead DSMs. Check the compression, I'll bet you 3 beers and a dozen wings the valves are bent. :(
TheGTkidsGSX
11-22-2003, 12:27 PM
yeah my poor car is dead as i have a mustang for my other car and sorry guys the 5.0 is my baby and is under construction so all funds go to that the eclipse was suppesed to be my winter car and not a project but oh well i know of two heads i can get so mabey after some time it will live again. thanx anyway but any suggestions are still welcome
im looking for gsx tranny as my engine has been replaced and its a fwd tranny so i have no driveshaft or anything but i still have the awd rear so mabey i can get some luck and find the parts to make it original again. later.....
