Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer
Old 11-20-2003, 12:56 PM   #1
ChrisD
ChrisD Normal reputation
Question Please someone Help 96 Blazer Wont start unless I jiggle the wires
My 96 Blazer wont start unless I jiggle the wires before hand that are connected to the battery.
It is a small rectangle shaped plug that one end goes to the battery and the other end goes into the wiring on the side wall passenger side of the truck. When I have came to a stop before it has just cut off and when I turn the key all lights come on but as soon as I turn it over everything turns off and I get no power until I jiggle the wires? Also when I turn on my blinker when it is running the amp gauge goes up and down between 12 and 14 and the lights dim in the vehicle. CAN SOMEONE PLEASE HELP...SINGLE FATHER ONLY WAY TO WORK AND HIM TO SCHOOL.
ChrisD is offline   Reply With Quote
Old 11-20-2003, 06:45 PM   #2
airforceone
airforceone's Avatar
airforceone
Send a message via AIM to airforceone
Does it have a good battery? Take it to an Autozone and have them test it. (Free!) Since you have to jiggle the wires, maybe you will need to get some new battery terminals. From what you descibed, I think this should fix your problem. When you go to Autozone, (a valuable source for information) describe you problem to them and they should be able to help you on the spot. Even if you have to replace the terminals, that job only takes a few minutes.
The world's greatest Air Force...well, at least we blow up the most stuff.
airforceone is offline   Reply With Quote
Old 11-20-2003, 07:49 PM   #3
ChrisD
Battery is good so is the alternator.
I dont really understand it.
Old 11-20-2003, 07:52 PM   #4
airforceone
airforceone
The terminal is the metal clamp or screw that connects the battery to the wires.
Old 11-20-2003, 07:53 PM   #5
ChrisD
Re: 96 Blazer wont start unless I jiggle the wires
Yes and those are good?
Old 11-20-2003, 07:56 PM   #6
airforceone
airforceone
Then check where the wire connects to the terminal.
Old 11-20-2003, 09:10 PM   #7
ChrisD
ahhhhhhhhh negative battery terminal was loose. Hopefully this fixed the problem. Will not know until in the morning or after a few starts
Old 11-20-2003, 09:29 PM   #8
airforceone
airforceone
to a job well done
Old 11-20-2003, 10:16 PM   #9
ChrisD
Thanks Man!! I appreciate it alot!! Love the gif of the welder..
I have a littel site but its for where I am from but hey check it out sometime..www.thehsvspot.com
Old 11-20-2003, 10:22 PM   #10
airforceone
airforceone
I just checked your site.....I don't think it applies to me as I'm on the other side of the world....
Bookmarks
Google
Web AF
