'93 cooling fan not turning onvnd 11-20-2003, 10:44 AM Hi, would appreciate some help. I had 1 instance of overheating. After some checking I noticed that the cooling fan did not turn-on after extensive idleing. But the fans do turn-on w/AC running. I replaced the cooling fan switch, but it still does not run. Any ideas? Have not seen additional overheating even though the fan does not turn-on. Is this normal? Does it need fixing? Thanks in advance. kings_blend 11-20-2003, 10:30 PM id just replace the whole fan, they go pretty quick, i gotta replace mine too it rattles but hasnt got to the stage where it dont turn on.... 92lx 11-21-2003, 08:04 PM run a 12v wire from the battery over to the fan and test it directly, if it doesn't run, replace the fan. - Nathan stopmenot2002 11-22-2003, 09:38 PM I Have Same Problm, When the Engine runs, the fan doesn't, but when I park and stop the car the fan started to runs after the car stop, it runs for 2-5 minutes. But I run a bypass(seperate wire) to test, and it runs, but not when the engine is needed. ??? Relay prblm?? Y. Help Thnkx 92lx 11-23-2003, 10:36 PM relay problem. - Nathan scarecrowdjinn 11-24-2003, 09:22 AM Try tracing the problem from the fan back to the battery using a multimeter. Honestly. The multimeter should be one of your most used tools in your tool box. vnd 11-24-2003, 09:28 AM Is there another relay besides the one in the fuse box? I have swapped relays in the fuse box with the automatic windows, but still have the same problem. Should I be looking for another relay for this fan? stopmenot2002 11-30-2003, 11:20 PM yesturday i was trying on i 95 the car temperature went up and stay allmost overheating, i notice that happen only i go 40+ mph any idea anyone, fan still doesn't works, it shouldn't be hight temp when trying on highway, more air blow into engine to keep engine cooler but dunno y, help? gailles 12-04-2003, 02:15 AM I'm not sure, but I think I have a similar problem to the person with the fan running after the car is stopped and switched off. After about a minute the fan comes on and runs for up to 5 minutes before stopping. Sometimes it runs for a couple of minutes and then stops for a few seconds and then starts again. While driving the car temp registers normal - just below the half way mark on the indicator on the dashboard. My garage replaced the thermostat, but I still have the same problem. Honda Accord 1995 with about 92,000 kms. Any help would be much appreciated. Thanks. stopmenot2002 02-02-2004, 06:53 PM Gailles, your car is normal, nothing wrong with it turning on after car stop when the temp is normal while driving. Automotive Network, Inc., Copyright ©2012
