Re: 3S-GTE ECU and injector Q's
cc will change with fuel pressure. 430 @38psi, 508 @52psi (base pressure) (numbers may not be exact, but damn close)
You can re-flash, ask Reg at RCTS in Calgary Alberta Canada.
For a little more cash , go standealone ECU , and pay someone to tune it.
Upgrading the ECU would only be perfect if the maps were programmed while the car was dyno'd or had a wb o2 system to tune the A/F .
Over the phone ECU upgrading will not be 100% perfect.. As every engine is different...
good luck!
