SR20DET Swap QuestionsAznVirus 12-11-2001, 11:30 PM 1. how much hp and torque does the DET have? 2. what choices do i have for the intercooler? 3. do i have to use a 91-93 harness? does 94-96 work? 4. where can i find JDM gaskets? 5. can i swap parts from my SR20DE to the DET? 6. what tranny should i use for it? 7. do i have to fabricate any piping? 8. what turbo is on the DET? how much lbs. of boost is stock? 9. what things should i change when i install the engine? 10. what ECU is compatible with the DET? 11. any special care i need to worry about? add to it if you have any questions. ill answer whatever ones i know, someone else please answer the rest. :D AznVirus 12-11-2001, 11:39 PM Originally posted by AznVirus 1. how much hp and torque does the DET have? 2. what choices do i have for the intercooler? 3. do i have to use a 91-93 harness? does 94-96 work? 4. where can i find JDM gaskets? 5. can i swap parts from my SR20DE to the DET? 6. what tranny should i use for it? 7. do i have to fabricate any piping? 8. what turbo is on the DET? how much lbs. of boost is stock? 9. what things should i change when i install the engine? 10. what ECU is compatible with the DET? 11. any special care i need to worry about? add to it if you have any questions. ill answer whatever ones i know, someone else please answer the rest. :D 1. Bluebird DET - 205 hp/ 199 lbs. of torque GTi-R DET - 237 hp/ ? torque 2. you can use the stock intercooler but will have to custom the hood to get cooler air or you can get a FMIC, but will have to fabricate all the piping. 3. ? 4. try courtesy nissan (800) 527-1909 5. some that you can use are pulleys, pop charger, exhaust... 6. you can use any SR20DE tranny to bolt on to the DET 7. ? 8. Bluebird DET - Garretts T25 6 lbs. of boost GTi-R DET - Garretts T28 9. Fuel pump, water pump, radiator hoses, rod bearings (recommended) 10. have to send in a P10 ecu to get retuned by JWT 11. all cooling systems must be bled, the DET is sensitive to air in the cooling system. G-Forces 12-12-2001, 08:40 AM Originally posted by AznVirus 3. do i have to use a 91-93 harness? does 94-96 work? 7. do i have to fabricate any piping? 3. Send your 91-96 ECU to JWT and they will send back a DET enabled ECU. :D 7. Potentially. However Hotshot is in the process of making an intercooler piping kit available for the P10 G20's. AznVirus 12-12-2001, 06:01 PM Originally posted by G-Forces 3. Send your 91-96 ECU to JWT and they will send back a DET enabled ECU. :D i was talking about the wiring harnesses :p not the ecu. i know george or luke can help me out on this one. please! :cool: Automotive Network, Inc., Copyright ©2012
