adjusting boostkokujin 12-11-2001, 09:58 PM how do you adust the boost on the 1g eclipse turbo, TD05h 14b? do you have to buy a boost controller or can it be manually adjusted without the use of an external wastegate. if so how do you go about doing this? pvang31019 12-12-2001, 04:18 AM Originally posted by kokujin how do you adust the boost on the 1g eclipse turbo, TD05h 14b? do you have to buy a boost controller or can it be manually adjusted without the use of an external wastegate. if so how do you go about doing this? you can make a MBC out of fittings from the local hardware store and 4-5 bucks out of your pocket...I'll try to get you the link later, I'm kinda lazy to search right now trmi-nate 12-12-2001, 01:10 PM try http://www.c-speedracing.com/howto/mbc/mbc.html it might still work Automotive Network, Inc., Copyright ©2012
