Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Oldsmobile > Aurora
Old 11-14-2003, 02:13 AM   #1
rg4541
rg4541 Normal reputation
Keyless Entry
Does anyone know how to program the keyless entry for a 1995 Aurora. Just got mine, pretty sweet, 75k miles on it, trying to fix up the transmission on it, replaced the break pads and now trying to program a new remote I got for it, from the dealer, <$120 for it, don't feel like adding to it by taking it to the dealer. Thanks!
rg4541 is offline   Reply With Quote
Old 11-14-2003, 02:25 AM   #2
Indy8
Indy8's Avatar
Indy8 Normal reputation
Re: Keyless Entry
Do you have the owners manual? It may be in there. I only have procedure for OBDII, if there's a diff.
Indy8 is offline   Reply With Quote
Old 11-14-2003, 09:27 PM   #3
97 silverbullet
97 silverbullet's Avatar
97 silverbullet Normal reputation
Send a message via AIM to 97 silverbullet Send a message via Yahoo to 97 silverbullet
here's how to do it.
Turn ignition switch "off"
Using a fused jumper, juper data line connector terminal 8 (blk/wht) to terminal 4 Blk close all doors
turn ignition switch "on" door locks cycle
press and hold lock and unlock button on one transmitter alter a 30 second delay the doors will lock and unlock
repeat step to program extra transmitters
do not turn off ignition, if switch is turned off the first transmitter will become inoperative.
disconnect jumper from DLC
that works
i did it.
[On his running for California Governor]
It's the most important decision I've had to make since 1978 when I decided to get a bikini wax.
-- Arnold Schwarzenegger
Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
97 silverbullet is offline   Reply With Quote
Old 11-14-2003, 10:18 PM   #4
Indy8
Indy8's Avatar
Re: Keyless Entry
That's what I used also, worked on two new remotes. I thought OBDI connector may be different than II. I can't get the perimeter lighting feature to program or work. Any help with this would be welcomed. BTW, gmpartsdirect.com has new remotes for $42.50 ea.
Old 11-15-2003, 01:10 PM   #5
rg4541
Thumbs up
Thanks for the replies, although I guess I am not that tech savvy, I have no idea what ="Using a fused jumper, juper data line connector terminal 8 (blk/wht) to terminal 4 Blk"= means. You think you could explain that in laymen terms? I would really appreciate it...
Old 11-15-2003, 02:05 PM   #6
Indy8
Indy8's Avatar
Re: Keyless Entry
I can e-mail the instructions to you if you want to post your address. We can't post images here. The DLC is under driver side dashboard. It's tapered on the ends. The wider horizontal row of female pin connectors is where you count from left to right(driver to passenger side), the 4th input and 8th input. The 8th is the last one. Some are color coded, some are numbered(very small). My car has neither, so count to be sure. Ideally, a fused jumper wire should be used to protect the electronics. Most use a SMALL paperclip. I used arts&crafts wire. Just don't damage the pin receptacle.
Old 11-15-2003, 02:59 PM   #7
rg4541
Re: Keyless Entry
I think I can receive e-mails now, thanks for your help!
Old 11-15-2003, 05:31 PM   #8
Indy8
Indy8's Avatar
Re: Re: Keyless Entry
Hang on, I'll dig it out and scan it ASAP.
Old 11-15-2003, 08:41 PM   #9
charlesnj
charlesnj Normal reputation
Send a message via MSN to charlesnj
DLC Picture
Hello I wanted to know if you could email me a Picture of the DLC. I really would apprecitate it. Thanks charleshartmann609@hotmail.com
charlesnj is offline   Reply With Quote
Old 11-16-2003, 04:16 AM   #10
97 silverbullet
you know where you plug the computer to the car that harness thats the DLC.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 11-16-2003, 03:25 PM   #11
hoot972
hoot972 Normal reputation
#8 is blk/wht #4 is blk. for a fused link take a 3 or 4 amp fuse and tape a wire to each end. if you can't see the wire color take the two screws out on either side and drop it down
hoot972 is offline   Reply With Quote
Old 11-16-2003, 05:38 PM   #12
rg4541
Re: Keyless Entry
I did it! Thanks to everyone...
RG4541
Old 11-16-2003, 05:53 PM   #13
Indy8
Indy8's Avatar
Re: Keyless Entry
Did you get your perimeter lighting feature to work?
Old 11-20-2003, 12:21 AM   #14
Spinman
Spinman's Avatar
Spinman Normal reputation
Have the same question regarding a 1996 Aurora...
Just purchased a new remote on ebay and need to program it to work (along with my existing unit).
Does anyone know if the instructions posted here for the 1995 model are the same for the 1996 model?
Not sure, but I believe the system changed in 1996 to the tear drop shapped remotes which support code hopping. My understanding is that the 1995 model had the old style square remotes that did not support code hopping.
Are the "fusable jumpers" available at auto stores - or would I need to build my own. I'd rather err on the side of safety and use a fuse in the circuit rather than the old paper clip jump...
Thanks!
Spinman is offline   Reply With Quote
Old 11-20-2003, 12:49 AM   #15
hoot972
Re: Keyless Entry
mine is 96 ands that how you do it. your remotes a #25678792.if your still not sure just make a fuseable link with a 3 or 4 amp fuse between two wires and your safe.
Bookmarks
Google
Web AF
