1998 Ford Taurus SEGrumpyGramps 11-13-2003, 01:10 PM I was wondering if anyone could tell me which fuse (under dash) or which relay (engine compartment) go to the horn and cruise control. My fuse cover and the engine compartment covers are not marked. I under stand that the horn and cruise control use the same relay. Earl sk8boarder 05-27-2004, 07:26 PM Look in your owner's manual, it give u a diagram of all the relays and fuses in the fuse panel, and tells you exactly what systems use each relay or fuse. irish30 05-27-2004, 11:08 PM In the engine compartment fuse panel the horn fuse is a 15Amp blade fuse, position number 19. Your speed control fuse is located in the Instrument panel fuse panel. It is a 15Amp fuse. Its position number is 28. The horn relay is located beside the battery in a relay box. :sunglasse Automotive Network, Inc., Copyright ©2012
