Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Taurus/Taurus Wagon
Old 11-13-2003, 11:42 AM   #1
bcmason
bcmason Normal reputation
Mercury Sable Heating Problem
I have a 1998 Mercury Sable sedan. The heat does not work -- it blows cold air.
Sometimes if I turn it off for awhile and turn it back on, it will blow warm air for a few seconds, and then blow more cold air.
I know there was a leak in the coolant overflow talk. I replaced the tank myself and then had Jiffy Lube run a full radiator flush and fill. The tank is filled to the upper bound of where it should be.
There are some comments here already about this same problem... but the radiator flush didn't work for me! Is there anything else this could likely be? Did Jiffy Lube perhaps do a poor job on the flush?
Thanks muchly.
bcmason is offline   Reply With Quote
Old 11-13-2003, 04:03 PM   #2
carmike1559
carmike1559 Normal reputation
next step is replace thermostat and gasket,it could be seized.good luck. mike
carmike1559 is offline   Reply With Quote
Old 01-29-2004, 06:24 PM   #3
nissan99
nissan99 Normal reputation
Re: Mercury Sable Heating Problem
hey I just fixed a 96 sable with the same problems, replaced the thermostat, then flushed the the system from the back. behind the block there are two hoses that go into the fire wall one of those comes up on the pasenger side and is easyer to detach the pressure clamp hook a hose to it, open the refill top and open the drain at the bottom of the radiator. I was shocked at how much rust came out. I let it drain for about an hour, well the heater works now, maybe jiffy loob just flushed it from the coolent resevor(where you add the coolent) and then let it drain out the bottom, that would not fix the problem. good luck I hope this helped
nissan99 is offline   Reply With Quote
Old 01-29-2004, 10:08 PM   #4
Indyrider
Indyrider Normal reputation
Check thread titled, (Taurus heater fix!!) Flushing the heater core worked great for me!
Indyrider is offline   Reply With Quote
Old 02-16-2004, 06:39 AM   #5
Chrisl2003
Chrisl2003 Normal reputation
Mercury Sable heater core problems
This must be a common Ford problem, regarding heater cores and no heat! I own a '99 Mercury Sable GS, my sister owns a '99 Ford Taurus SE, and my brother in law owns a '02 Ford Ranger XLT. All 3 vehicles do not have heat at all. My vehicle and my sister's vehicle both needed new coolant reservoirs, both were leaking where the top is glued to the actual reservoir. I have flushed out the cooling system, but I did not remove the heater core hoses. My temperature guage is reading normal at operating temperature, so I do not believe the thermostat is bad, I will try back-flushing the cooling system with the heater core hoses off and post a reply as to how things went!
Chrisl2003 is offline   Reply With Quote
Old 11-25-2004, 02:34 PM   #6
KellyLogue
KellyLogue Normal reputation
Exclamation Taurus 1998 no heat or hot defrost Help!
I just purchased a 1998 Ford Taurus SE Wagon. The car has 194,000 miles. Mostly all highway miles. The car looks and drives great. I had my mechanic look it over and drive it as did I. Neither of us thought to check the heat. I doesn't seem to work. I does warm for a few seconds then blows cold air. I will have the thermostat and the back flush checked. I pray that the heater core does not need replacing. I hear that this item is not a low cost repair. I am grateful to have the car. I simply did not check this issue prior to purchase.
Kelly
KellyLogue is offline   Reply With Quote
Old 11-29-2004, 10:46 AM   #7
JAMoore
JAMoore Normal reputation
Re: Taurus 1998 no heat or hot defrost Help!
I have a 1998 Ford Taurus with roughly 200k miles on it. It was been a fantastic car with nothing but normal wear and tear maintainence needed. However, the heat has just now stopped working. I had it flushed and was told the the heater core needed to be replaced. Now, I'm not one to readily trust mechanics so I was wanting to see if anyone else had the same problems and the fixes they tried first. Replacing a heater core is not an inexpensive undertaking. Thanks.
JAMoore is offline   Reply With Quote
Old 11-29-2004, 09:09 PM   #8
fordfool
fordfool Normal reputation
warm your car to temp, and feel the upper radiator hose. if its hot, your themostat is ok. pull your hoses at the heater core, and flush it yourself with a garden hose. put on a new radiator cap (only $5 at the local autozone, etc.) and hope for the best. if it gets some heat, but not very good, rev your engine up to 2500 to 3000 and hold it for a bit, if you got heat then, suspect you water pump fins are worn down.
fordfool is offline   Reply With Quote
Old 10-28-2005, 02:01 PM   #9
shacksprebuilt
shacksprebuilt Normal reputation
Unhappy sable heat
1998 Sable heat hasn't worked. Power flushed and back flushed heater core. Replaced thermostat 2 times. Found a/c running all the time. took out fuse to a/c, backup lights,. Have heat-but not good heat. Also felt lines going into heater core-they are hot-but 2nd mechanic found a bypass line above heater core-heat could be circulating thru there, and not thru core. I will recheck for leaks, as well as show mechanic post on fins (earlier post). Car does heat when revved. But heat gave into cool air again after hours of running car. Again, fuse is taken out of a/c -only way I've gotten heat so far. I have heard that when a heater core goes bad it leaks into the cab.
shacksprebuilt is offline   Reply With Quote
Old 01-02-2009, 12:54 AM   #10
poetrylvr1338
poetrylvr1338 Normal reputation
We found this while trying to figure out why my daughter's '98 Sable's heat wouldn't work. We had the radiator flushed, nothing. We checked the thermostat as suggested by feeling the heater hose, it was hot. What finally worked was pulling the hoses by the heater core and using a garden hose to flush the heater core. What wasn't mentioned is that you have to be very careful to use minimal water pressure so you don't destroy the heater core. Thanks for all the useful information we found here, figured we could pass on what we learned about not using too much water pressure to flush the heater core.
poetrylvr1338 is offline   Reply With Quote
Old 01-02-2009, 11:52 AM   #11
shorod
Taurus Guy
shorod's Avatar
shorod Normal reputation
Thanks for passing on that tip, and welcome to the forum!
Just out of curiosity, did you end up popping your heater core by using too much pressure, of did you learn that tip prior to causing damage?
-Rod
shorod is offline   Reply With Quote
Old 01-02-2009, 08:01 PM   #12
CrapaTaurusWrecks
CrapaTaurusWrecks Normal reputation
I have a 1996 GL wagon with only 75,000 miles on it and has always been well maintained. It has always been a souther California car so it hasn't had to endure any extream cold temperatures. The car has always had antifreeze and the heat has never given me any problems but several months ago when a heater hose sprung a leak on me I flushed my system and holy moly! I could not believe the amount of rust that came out. After seeing this first hand I would recommend flushing the core to anyone that hasn't done it in a while.
TaurusGLenn
CrapaTaurusWrecks is offline   Reply With Quote
Old 01-02-2009, 10:42 PM   #13
Colt Hero
Colt Hero Normal reputation
poetry:
I've been flushing my heater core near the firewall for several years now with maximum garden hose pressure and no problems. You'd probably have to neglect your cooling system for a decade to blow up a heater core with a garden hose - and even then I'd bet you'd still be OK.
My Taurus GL wagon is 11 years old now with 164k+ miles on it and the heater core, radiator, hoses, and thermostat are all still original from the factory.
Colt Hero is offline   Reply With Quote
Old 01-09-2009, 06:16 PM   #14
2percent
2percent Normal reputation
The heater cores on these seem to gum up alot my wife has a 96 taurus and ive flushed it twice and have to do it again works great just clogs to easy. I have heard alot of complaints about these heaters but this worked for me twice
2percent is offline   Reply With Quote
Old 01-09-2009, 08:54 PM   #15
Colt Hero
I just replaced my water pump which had disintegrating fins/impellers on it. I can tell there is a difference now with the heat, but it still could be a LOT better. Maybe one more flush will blow out the old water pump debris and I'll be able to get through the winter with sufficient heat.
Bookmarks
Google
Web AF
