my 92 lemans will not runbubbafart 11-11-2003, 04:52 PM I have installed a new alt and batt starter and ignition switch// It runs for about 5 min and dies and have to wait about 4 hours to get it started again. I tryed starting it again today and the batt was die, I did get it started but it only ran for about 5 min and died again and now i have tro jump start it all the time.ps the fuse for the radio blows and the fuse for the gages blows too then it started to die at first time it happen to me... now i do not have the fuses in and it still runs, When it does run it runs good but then dies. Im stumped and wish for some help. I think it could be the the carb or the catt vacume line it could be anything help me please thanks or call me at 604 526-1916 ask for chico thanks curtisbobbie 05-25-2004, 07:57 PM did you ever figure it out? Some common problems are clogged cattilitic converts, clogged fuel filters, faulty fuel pumps that run only part of the time. If you respond, maybe we can trouble shoot your problem. ablueyedsissy 06-07-2006, 04:00 PM Can someone help me with my 92 LeMans? It used to run pretty good IF i kept it above a half tank of gas. Not sure what that means. Now it is hard to start but once started will run good for about 10 minutes then start chugging. It will keep running as long as I keep pumping on the pedal (sometimes). Its like not enough fuel is getting in there or something. Any ideas. If I let it sit for a few hours it will start right up again but do the same thing over again. WHen i pump on pedal to keep it running, is this dangerous? Wondering if this is something expensive????? Automotive Network, Inc., Copyright ©2012
