HUXRacing Complete TurboSetUp 4Sale! 450+WheelHpwr (good buy)
TOYRACR
11-10-2003, 03:28 PM
(im just a friend posting this for Emily and Erix Hux www.HUXRACING.com)
We are in the process of building another motor. Would prefer to sell as a complete setup. This setup is from our own red Mr2 seen at www.huxracing.com.
-The list is as follows:
Hux Racing Exhaust Manifold Stainless.Steel. Flange to Flange
ITS Turbo 60-1 compressor
T3 stage 5 turbine in special T4 chermachromed housing
Turbine housing has a ceramic heat shield
Oil feed line, oil drain line, & pan fitting
Turbonetics Racegate
Hux Racing Downpipe 3" chermachromed
Includes flex pipe for WG connection
Clears AC & requires remote oil filter
Spearco air/water intercooler
2 1/2" inlet 3" oulet modified for application
Enlarged water ports w/bleed port & S.S. stands
Silicone blue hoses
Intercooler to TB Elbow
Constant tension hose clamps
BBK Throttle Body
75mm w/Toyota Throttle, & cable braket
HKS Super Sequential Blow Off mounted to I.C.
Hux Racing Intake Manifold
Full sheet 6061 Aluminum Long Runner manifold
Setup for staged Injection, 2nd TFFR mounts to Intake
Aluminum Intake brace
Hux Racing Top Feed Fuel Rails (2)
Upper standard TFFR & Lower Staged injection
Fuel line between rails
Water neck elbow S.S.
red anodized relocating brackets for IC clearance
hose & clamps
Hux Racing Air/water trunk mounted tank, water pump,&
Hux Racing custom trunk mounted fuel cell w/ Paxton 500lb/hr fuel pump are available for additional fee.
Purchaser will receive all info necessary to duplicate motor from which this setup was removed from (cam specs, valve train, etc.)
THE Total for setup $5500.
Please Call 321.638-4077 or email huxeric@hotmail.com
for any Questions.
http://images.cardomain.com/member_images/8/web/380000-380999/380243_76_full.jpg
:shades:
http://images.cardomain.com/member_images/8/web/380000-380999/380243_53_full.jpg
This set up can produce more than 450wheel Hpwr
its just that the stand alone unit that the Hux's were using before was only good for up to 21lbs of boost. With a different stand alone computer like the new Accel DFI VII that just came out for 4cyl turbo Motors or just an Electronic Boost controller - you can produce alot MORE power using this Set up. :smokin:
FYI. :iceslolan
The motor it self is not for sale But Everything else is
All parts are used and do not have alot of miles on them At all
Seriously Everything is in Spectacular Shape.
