Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Probe
Old 11-10-2003, 12:59 PM   #1
ahull
ahull Normal reputation
94 Probe GT
I have a 94 GT and the check engine light is on. i bought the car with the light on. I have pulled out 2 codes, 15 & 17. I have read that these are for the O2 sensors. I have also heard that the engine temperature sensor may be the culprit, is the engine coolant temperature the same as the engine temperature? The RPM of the engine is at 1500 when cold, but then goes up to 2000 when it warms up. any help would be appreciated.
ahull is offline   Reply With Quote
Old 11-11-2003, 11:05 AM   #2
Fizer70
Fizer70 Normal reputation
Re: 94 Probe GT
You are right on the codes. Replace the front sensor with a new one. It's pretty easy. The size of the O2 sensor is 23 mm. So you can use a 23 mm wrench on it. You can also get a O2 socket to remove it as well. If you don't have the right tools, you could try an adjustable wrench, but be sure to soak the O2 sensor in some rust penetrant (I recommend PB Blaster brand stuff, WD40 doesn't work as well)
Check your coolant level. Make sure it isn't low. A low coolant can sometimes cause idle problems. Be sure your engine is colde before you remove the cap.
Fizer70 is offline   Reply With Quote
Old 11-11-2003, 12:14 PM   #3
ahull
Re: 94 Probe GT
Thanks I'll try that.
Bookmarks
Google
Web AF
