90 Passat Grill
aczlan
11-09-2003, 01:51 AM
I have a 1990 passat with the stock (solid) grill and am looking for a way to get it running cooler.
Currently the engine temp climbs from the 195 or so it is at when moving to 230F when stopped for about 2 mins. I have checked and the cooling fan is kicking in and running and the thermostat opens fully at 195 like it is supposed to.
I am currently looking at putting in a mesh grill but am open to other alternatives
It is all stock with the exeption of the tranny which I had about replaced 2 years ago.
Thanks
Aaron Z
Llogoaero
11-09-2003, 11:52 PM
Aaron,have you checked your rad for blockage ? You might consider flushing the entire cooling system as well.Try draining the rad and having a look inside, if it is the original rad chances are that the tubes could be corroded/blocked.Another thing is the water pump and belt.Check to make sure the belt tension is tight.
Good luck
aczlan
11-10-2003, 09:47 AM
Good luck
I have checked my rad and it is clean I had it flow tested recently and they said it wasnt blocked, just checked and the belts are all tight
Thanks
Aaron Z
HeirMuench
11-11-2003, 03:39 PM
Not sure, but you might check the thermal switch in the radiator. It is separate from the temp sender for the dash.
