NE 1 Know Anything About A '67 Pontiac Lemans
67LemansMan
11-08-2003, 12:49 PM
I have a ? about a '67 Pontaic Lemans. I need to know if the number on the block will be the same as the VIN number? Trying to find out if my car has the original engine.
69droptop
11-08-2003, 03:59 PM
Check out www.classicalpontiac.com. Someone there should know for sure. You should have a machined area on the front passenger side of the block. There will be a two letter code and a six or seven digit number stamped there. There is another machined area below this next to the timing cover that will have a partial VIN of the car the engine came from. See if it matches your VIN. You will probably have to use a wire brush to clean the area off if as the letters are pretty small.
67LemansMan
11-09-2003, 09:51 PM
Thanx for the info I will look and See.
