IAC (Idle Air Control) is going bad?mcdanida 11-05-2003, 04:11 PM My computer generated a number 35 code with the flashing "Check Engine Soon". This indicated a bad Idle Air Control circuit, valve, and/or sensor. The only thing that happened, which started this, is I idled low once and my engine stalled. It took 2-3 times cranking to start it, but once it started again, it ran fine. I only worry because the "Check Engine Soon" light stays on, and the same code remains #35. Should I ignore this? Should I replace the sensor and/or valve? Should I clean the sensor and/or valve? Looking for anybody that has had this problem and resolved it. GMMerlin 11-06-2003, 12:11 PM Code 35 is for an Idle speed error.... if the ECM sees that the idle speed is 150 rpm higher or lower than commanded, the SES light will come on. Check for vacum leaks and for the correct pcv valve (wrong pcv could cause idle problems) The IAC valve could be sticking. mcdanida 11-06-2003, 06:17 PM Thanks. I replaced the IAC Valve, disconnected from my battery terminal in hopes to reset computer, and everything is looking GREAT!! At 115,000 miles and going strong again! The old IAC Valve looked HORRIBLE! MXLT95 12-09-2003, 01:45 PM Hi you all, I'm new to this site. My sister has a '95 S-10 Blazer and seems to have a similar stall problem and 2-3 times cranking to start it but no CE light. Question is which one is the IAC valve?. I don't have Haynes or Owners manual, does anyone has a picture showing the IAC?. Thanks. MXLT95 12-09-2003, 02:00 PM Thanks mcdanida but excuse my ignorance, I don't see the picture ! mcdanida 12-09-2003, 02:06 PM Trying again. HTML sucks in here. This should answer any of your ?? Model 700 Throttle Body Injection (TBI) unit 1. Air Filter Gasket 2. Flange Gasket 3. Fuel Meter Assembly 4. Fuel Meter Body Screw 5. Fuel Meter Body-To-Throttle Body Gasket 6. Injector Retainer Screw 7. Injector Retainer 8. Fuel Injector 9. O-Ring - Fuel Injector Upper 10. O-Ring - Fuel Injector Lower 11. Injector Filter 12. Pressure Regulator Cover Assembly 13. Pressure Regulator Attaching Screw 14. Pressure Regulator Spring Seat 15. Pressure Regulator Spring 16. Pressure Regulator Diaphragm 17. Fuel Inlet Nut 18. Fuel Nut Seal 19. Fuel Outlet Nut 20. Throttle Body Assembly 21. Idle Stop Screw Plug 22. Idle Stop Screw 23. Idle Stop Screw Spring 24. Throttle Position Sensor 25. Tps Attaching Screw 26. Idle Air Control (IAC) Valve 27. IAC Valve Attaching Screw 28. IAC Valve O-Ring 29. Tube Manifold Assembly 30. Manifold Attaching Screw 31. Tube Manifold Gasket Sorry, try this location for picture - these forums are not HTML friendly http://www.s10forum.com/forum/attachment.php?s=&postid=264916 MXLT95 12-09-2003, 02:24 PM Got it! Thanks a lot mcdanida, I'll check it out tonight and find out, I might be lucky. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
