Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Volkswagen > Nonspecific
Old 11-05-2003, 08:53 AM   #1
K_millar
K_millar Normal reputation
Question 1.8L 8-Valve
I just purchased two old school Jettas for very cheap.
I'm new to VWs and know nothing. I need a head for my '90 and was wondering if the 16 valve head would fit on my block and what complications I might run into.
Thanks
KMillar
K_millar is offline   Reply With Quote
Old 12-06-2003, 07:21 PM   #2
noodle32
noodle32 Normal reputation
Re: 1.8L 8-Valve
You should have little to no problems - A1's and A2's are Golf and Jetta body codes - which gives you basically a wide array of engine options - including 16 valve, G60, VR6 and 1.8T engine types - these cars were designed to be fabricated - if you had a Fox on the other hand - which has a longitudinal engine - than you could run into probs - but this is a very possible engine transplant project - I say go for it if you can
noodle32 is offline   Reply With Quote
Old 12-08-2003, 03:02 PM   #3
boschmann
boschmann Normal reputation
Re: 1.8L 8-Valve
A 16 valve head will fit right onto an 8 valve block, but the pistons are different. They are the same bore & stroke, but the 16 valve pistons have cut outs for the intake valves. Of course you would have to use both manifolds, etc... from the 16 valve also.
boschmann is offline   Reply With Quote
Bookmarks
Google
Web AF
