How do you get at the clearance lights on P10zykotik 12-10-2001, 06:34 PM I'm talkin about the the small 194 bulb lights in the same casing as the headlights in a P10. i_rebel 12-10-2001, 06:39 PM At the far side of the headlight housing (very close to the fender), there is a separate harness/set of wires for that bulb. You have to firmly hold it while, twisting it (can't remember if it's clockwise or counter) and you will be able to free it . . . I ALWAYS HAVE A VERY HARD TIME GETTING THESE DAMNED BULBS OUT . . . AND A PARTICULARLY HARD TIME GETTING THEM BACK IN!! zykotik 12-10-2001, 08:13 PM Thank you very much man! I was tugging at that and I even thought maybe I had to turn it but I wasn't sure so I left it there hehehe.. I know what I'm doing tomorrow. A380Driver 12-10-2001, 11:10 PM OK parking lights...well im really drunk so lets see how ewll i explain this. If you need to...use like a pair of pliers to twist the harness...you will be albe to twist it so it pops out. If you cant then you can take out the FOUR bolts that hold the headlight assembly to the radiator core, and then after that you obviously have full acces to anything. Dont worry about giving it some force, sometimes it will take alot to turn it. Good luck. i_rebel 12-11-2001, 12:44 PM Oh yeah . . . It helps to push in while turning it . . . you know, like push the little harness towards the front of the car while you are turning it . . . Automotive Network, Inc., Copyright ©2012
