Touch Up PaintBPDP825 11-04-2003, 02:43 PM I believe my car was hit with an egg or some hard object on halloween. It left a circle of paint chips on the passenger side door. I had some touch up paint at home, so I proceeded to cover it up. It now looks much better than it originally did, but it is noticeable that touch up paint was used. What should I do to make the touch up paint blend in better with the actual paint? Thanks for any help. AceNZ_20v4AGE 11-08-2003, 07:56 PM try polish, if its not metallic paint you could use a cut polish, and if not then... door re-spray tol 11-11-2003, 09:49 AM I had a similar problem. If you are ready to spend $6-8,Try your local toyota dealer. They give you the exact paint depending on your VIN. It exactly matches so works great. Automotive Network, Inc., Copyright ©2012
