drove car through waterOnlyeyes 11-04-2003, 01:17 AM I have a buick sedan that I drove through some water tonight.... It was not more than 6 inches of water at most, but after I got through it, the brakes didnt work very well. When I got home (like 5 mins later) I smelled a burning smell and smoke was coming out of the hood. No engine lights were on and the temp. gauge was in the middle. What do you think happened, is it major and what will it cost to fix? thanks! tman 11-04-2003, 07:20 AM you probabaly splashed water onto the exhaust manifold, or the brake rotors. Onlyeyes 11-04-2003, 10:05 AM ok well hopefully it will start this morning with no problem... Onlyeyes 11-04-2003, 12:41 PM Ok i started it and drove around the block a bit, it seems to be working fine....do you think i should get it checked out anyway? tman 11-04-2003, 05:12 PM You should be fine, but the cool water on an engine block could have caused a crack in the exhaust manifold, or worse, the block. There is something I read about that you could spray on the engine, and it wouldmake the cracks glow, but someone else will have to tell you about that. If it runs fine, then consider yourself lucky. Hypsi87 11-09-2003, 06:33 PM the stuff that you spray on the block is made by mangaflux. We use it at Caterpillar alot to inspect wields for cracks. It glowes under a black light. It's pretty cool. Ill get the actual name of the stuff tommrow. Andy tman 11-09-2003, 06:38 PM mangaflux Thats what i was thinking of! I was trying to say magnum or magnuson(the SC company lol!) Hypsi87 11-09-2003, 07:49 PM mangaflux makes the product but it is called something elese. Mangnafluxing is when you magnatize a piece of metal and brush Iron powder on the metal. The powder goes to the cracks and reveals them. Here is how it works. When you magnatize the metal, the whole piece of metal is like a magnet. When there is a crack the two ridges of the crack become opposite charges. and attracts the powdered Iron to the crack. If you ever get a chance to see the process check it out I think it is pretty amazing. Andy tman 11-09-2003, 10:04 PM I remember seeing it in a school textbook or something, it showed a crack glowing an amber/orange color. Onlyeyes 11-09-2003, 11:36 PM ok i will check that out, but now its been almost a week with no problems...do you really think i might have a crack? tman 11-10-2003, 07:10 AM if it runs as good as always, with no problems, then your probably alright. Automotive Network, Inc., Copyright ©2012
