wher is egr valve?
msgale
11-02-2003, 03:16 PM
2000 odyssey,
code says egr low flow, so i assume its somewhat clogged,
But wher is the egr?
itry2fly
11-18-2003, 07:34 PM
There is an update with these vans with EGR codes (insufficient flow or egr lift) with Honda. Basically, there is a kit available to repair which is a steel sleeve and EGR valve. IF you have less than 80,000 miles on your van, you are covered under this extended EGR warranty. (ie. FREE). The bulletin no. is 00-009. The check engine light will need to be on when you bring it in, Honda doesn't like to just take word for it :) Let me know...
CR
msgale
11-23-2003, 04:25 PM
thanks for the tip!
dealer said, yes, they fix free. havent brought it in yet,but looks like i'm covered.
msgale
01-11-2004, 10:58 AM
i did bring it in, they did fix it, all free.
thank for the tip!
PFCfutrell
01-18-2004, 05:25 AM
Exhaust Gas Recirculation... it's an emmision control :)
Redcastle
08-25-2006, 10:59 AM
:banghead:I am having the same exact problem and want to change the valve myself. Where is it located?
