Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Nissan > Primera/G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 10-31-2003, 08:08 PM   #1
NE7X
Banned
NE7X Normal reputation
How do you remove the fuel pressure valve?
My 1994 G20 fuel injector #4 is open and needs to be replaced. I don't want to remove the entire injector fuel tube assembly from the intake manifold, this would require a considerable amount of extra work. I have already successfully replaced fuel injectors 1, 2 and 3 by coming in at 90 degs between the engine block and intake manifold using needle-nose vise grips. I'm able to remove the two Phillips screws holding down injectors 1, 2 & 3 without issue. However I can not get to one of the two Phillips screws holding down fuel injector #4 because its behind the vacuum pressure regulator valve. So my next step is to remove the vacuum pressure regulator valve.
There are two screws holding the pressure value to the fuel tube assembly. However once I remove these two screws, the vacuum pressure regulator comes loose from the fuel tube assembly, however will not separate. There seams to be some sort of "tongue" coming from the bottom of the pressure regulator valve to the inside of the fuel tube assembly. This tongue is preventing separation.
Does anyone know what the trick is to removed the vacuum pressure regulator valve from the fuel tube assembly?
Thanks, Tom...
NE7X is offline   Reply With Quote
Old 04-29-2004, 01:57 AM   #2
mcguiver7
mcguiver7
Send a message via AIM to mcguiver7
theres just a O-ring on it. should pop out with a bit of force. also how the hell did you remove the injectors w/o taking off the intake mani? mine were always a bitch to get out even w/ the mani out of the way.
matt
mcguiver7 is offline   Reply With Quote
Bookmarks
Google
Web AF
