1995 jetta Gl III to vr6 swap
sle3pychild
10-31-2003, 07:08 PM
is it really worth it to swap my 2.0 Liter engine to a vr6???? if it is .. is it possible.. where can i buy an engine and what else would i need. transmission??? ect...
or should i just turbo out my 2.0 l engine for the money that imma spend on the vr6.. lata...
Midnyte
11-02-2003, 08:07 AM
I'm not totally sure of the specifics for what you'd have to do. I know you'd have to swap computers for the engines. The mounts for the VR6 are build into the chasis, so you shouldn't have a problem there. Tranny- automatic or manual?
I've got a 96 VR6 for sale. It had 50k miles on it when the Jetta it was in got T-boned. Its block, heads, manifolds, ac compressor, ps pump, and alternator. I can get a hold of an maf if you need. Find out what you wanna do first (hint- you can stage II turbo the VR6 and have a 360 horse monstrosity that will demolish anything on the road..just and idea)
lates
Midnyte
bobalobagous
12-14-2003, 08:06 PM
I've been trying to figure out the same thing, turbo or swap. Apparently to do a swap you have replace a lot of things for the added weight, fuel consumption and just having a swap...meaning you have to put in vr6 suspension, gastank, ECU, harness, etc.
I think it's worth it to get a vr6, it's got a lot more potential than the 2.0(after forced induction, what else can you really do to it?). The only upside to a turbo 2.0 is that no one really has them, and vr6s are pretty common.
Do whatever you think is best, vr6 will end up being more money (I got quoted $8k from a shop, but that was for everything and pro done, you can do it cheaper), but 2.0 won't give as much results.
Hope I helped at all.
flylwsi
12-15-2003, 07:56 PM
that's not an easy answer.
eip has great turbo kits for the 2.0, but you can keep the vr6 stock and outrun the turbo'd 2.0.
you can then stroke the vr6, turbo the vr6, stroke and turbo the vr6, etc. there's so much you can do.
or maybe you should consider a 1.8t swap. it'll bolt to your trans. that's a thought, huh.
a used 1.8t will set you back about 3k, but it's a great alternative. chip and exhaust, and you're at 200+hp. not bad. cheaper than a vr6 swap.
bobalobagous
12-15-2003, 08:43 PM
I was really looking at it from my point of view when i said that. Once i choose one of those routes i'm going to be broke for a while and then slowly be able to mod things. It's really easy to say "turbo a vr6", but it's a swap and a turbo kit, thousands of dollars a normal person doesn't have. I understand where you're coming from, but i would much rather have a 50K mile vr6 than a 100k+ 2.0 with a turbo. Plus the fact that i really do believe there is no replacement for displacement kind of biases me.
I do like the idea of putting a 1.8t into the car, but are you sure it will bolt up? Keep in mind we are talking about 3rd generation Jettas.
I'm not trying to be a dick with all this, i just don't know any other way to say it.
If you do want to turbo, ATP also has a great kit, and if you don't want to spend $2500+ on it, you can go on ebay and get a kit from some company that uses garrets in their kits, everything minus an intercooler for $1200, it will work.
Write back because i'm running out of ideas to help my jetta out.
flylwsi
12-16-2003, 12:24 PM
on www.overboost.com, there was a guy who dropped a 1.8t into an mk2 golf, and used the jetta a20 trans. it'll bolt up. my friend has a s/c'd 97 2.0, and is considering the 1.8t swap as well.
http://overboost.com/story.asp?id=1015
spasticone
12-18-2003, 01:42 PM
Consider other turbos. I used an audi 5 cyl turbo car as a doner and swaped all turbo parts into my jetta. Manifolds would be your only real problem.
one word of advice. TUNING. its a pain on a turbo crossflow head car.
bobalobagous
12-18-2003, 11:09 PM
i want to kick myself in the balls for getting a 2.0 every time i try to think of a way to make my car faster or read stuff like this
mkryszczynski
05-26-2011, 08:28 AM
i have a 95 jetta Gl III and i want to do an engine/transmission swap for a 1996 vr6 from a passat. is it worth the work? and what would i have to do to get it running in the jetta
