Offset for Integra with 16"
hybrid180
10-31-2003, 01:39 AM
I am looking into getting some new wheels for my 95 GSR and was wondering what is the optimal offset for it with 16" wheels? I read one post which said 42-45 is good but I was wondering if that applied to 16" wheels? I was mainly considering some wheels with a 40 offset, is that going to be ok? I do plan on eventually lowering the car.
Thanks
hondaracer
10-31-2003, 01:44 AM
Thanks
40 should be just fine. I believe that 43 is a good offset though for integras and it works out well in every situation.
TheNotoriousMogg
11-02-2003, 04:53 AM
40 will be fine
BullShifter
11-02-2003, 02:17 PM
:iagree: wheel offset changes the track width of a car. track is the distance between the center of each rim.(left to right) the wider, the better! More positive offset with narrow tires is better than less offset with wide tires. Since wider tires do not change track - track can also be changed with performance type wheel spacers.
Recommended Plus Sizes
PLUS 1 SIZE(S)
Require 16 inch wheels
205/45R16 (http://whalentire.com/tiresize.cfm?tiresize=2054516&manu=&finish=&vehicle=45&sorttype=1&onhandlimit=1&boltpattern=0&diameter=0&smallwidth=0&largewidth=0&npp=0&crn=0&alt=no) 0.18 Inches shorter than stock tire
215/40R16 (http://whalentire.com/tiresize.cfm?tiresize=2154016&manu=&finish=&vehicle=45&sorttype=1&onhandlimit=1&boltpattern=0&diameter=0&smallwidth=0&largewidth=0&npp=0&crn=0&alt=no) 0.67 Inches shorter than stock tire
