hey
TurboCivic
12-09-2001, 11:04 PM
Areu trying to make me blow my engine to smitherines?????
20 punds , yeah even if i put fuel pump injectors and remap fuel board retard ignition engine will go in months
U say to turn up boost well i got a electronic boost controller and is turned to 7 psi.
I do have 270 cc rc injectors not installed cause of over riched conditions!!!!!
the max i would go is like 8 psi 3# over the stock setting!!!!
I want to run 8 psi what u tink seriously
Gimme a good answer and not like yeah run 20 pounds(i can see high boost on twin cam motors h22a will handle D16Z6 no way!!!!!!
I went through two motors already i know these things
TurboCivic
12-09-2001, 11:06 PM
This was a reply to previous message
(# on turbo)
pvang31019
12-10-2001, 02:25 PM
I said that I've tried 20lbs on a bone stock motor and it held up for a while(a d16z6)...TUrn up your boost up to 8lbs, install those damn injectors(tune them down with a FPR or AFC), and go boosting....
pvang31019
12-10-2001, 02:28 PM
here's a pretty much stock d16y8 with 10lbs
http://www.honda-tech.com/zerothread?id=89693
Racing Rice
12-10-2001, 06:13 PM
The big key to that was the fact that he was running a thicker head gasket too..This drops compression in the motor which will allow you to boost a little more. Plus it depends on the motor, and how well it is tuned..
TurboCivic
12-11-2001, 01:17 AM
Hey thats a mean link u got there dood right on!!!!
Got a bit lost in that discussion though!!!
So:
Blue Box(FMU)
Apex VAFC
Fuel Pump
Vortech 10:1 FMU(Whats this on here i don know))???EXPLAIN????
pvang31019
12-11-2001, 03:54 AM
the vortech FMU is rising rate fuel pressure regulator...it increases fuel depending on boost...they come with all the regular drag, revhard kits...it's the little blue anadized thing always sitting on the firewall by the brake master cylinder
