Remote Starting 5 Speed
oedomsa
12-09-2001, 09:40 PM
Remote Starting A 5 Speed
fortyoz2eric
12-13-2001, 06:47 PM
what?
1989 DX R
12-13-2001, 08:42 PM
could you be a little less specific?
oedomsa
12-14-2001, 09:23 PM
i was asking if it was possible to remote start a 5speed transmission, but it was my 1st time posting so i screwed up, i reposted it elsewhere and got plenty of replies..thanx for checking my ? though.
1989 DX R
12-14-2001, 09:41 PM
Probably really hard to do, considering you should always have the clutch in when you start it, and remote starting, even in neutral could be dangerous...
89ssgti
12-30-2001, 04:58 PM
Remote car starter come in auto or manual variety.You can remote start a 5 speed safely and quite easily.
You just need to program it with the engine running in neutral with the handbrake on.
And it will then start just like a normal car starter.
1989 DX R
12-31-2001, 05:55 PM
I guess you dont have a carb huh? Lol, i gotta give my car some good lovin' with the gas to start it on cold days.
89ssgti
01-01-2002, 01:31 PM
Originally posted by 1989 DX R
I guess you dont have a carb huh? Lol, i gotta give my car some good lovin' with the gas to start it on cold days. Actually,one of my friend had one on his carb'd truck.The installer just programmed a trunk release motor to push on the throttle before it actually started.
Anything can be done.
Tireburner
01-07-2002, 02:39 PM
Remote starting a manual transmission vehicle is generally not recommended.
Clifford Intellistart 4 can be programmed for manual transmission vehicles. With the vehicle key started, you remote start the vehicle, exit the vehicle, close the door and arm the alarm. The car will then shut down. Now as long as the doors don't come open on the vehicle, you can safely remote start it.
Otherwise, there are some adaptors that go around the stick shift, that you adjust so it knows where neutral is.
Make sure the parking brake is used as a shutdown, so if the brake is not set it won't start.
I have seen both systems fail, so beware!!
ponchonutty
10-24-2003, 08:12 PM
Yep, done it plenty of times but only as a cash only basis!!!
