Egr Code 32 Problems
blackhawk5177
10-28-2003, 10:52 PM
94 Gmc K1500 4.3 V6 Keep Haveing Egr Problems I Have Replaced Egr And egr Solenoid . I Have Replaced Map Sensor, Even Cleaned The Intake And It Is Still Displaying Code 32. I Even Reset The Ecm.i Would Appreiate It Thankyou For Ur Consideration, Sincerely Jack
567234ta
10-28-2003, 11:56 PM
is the vehicle running like it has a cam the size of mount olympus?, have you taken the egr out to clean it and found that it was a little piece of carbon in it?
sounds like the common problem ive seen on several of them.
i dont know what the code 32 means probably that its not functioning properly.duh,
the way i have found to eliminate this problem after having it cleaned at the dealer, then replaced , which was astronomical in cost for those 2 things, have the same thing happen after 1 week of getting a new one. i so i cleaned every time for the next 8 or 10 times it happened until i was about to drive it into the lake.
what i found out was that the back pressure was too great. so i got a flowmaster 50, its a little loud but it hasnt happened since.
im sure there are other high flow exhaust systems that will reduce the back pressure and still be fairly quiet.
blackhawk5177
10-29-2003, 06:36 PM
i already have an high performance muffler and that does not solve the problem....its already been changed out its a brand new egr valve on there. the manual that i have says that the oxygen sensor can also send off a egr code 32 ...i was wondering if you have ever heard of this or of anybody else having this problem and it being that it was the oxygen sensor. your reply to this would be greatly appreciated .
odie13
11-12-2003, 11:05 AM
check the vacuum lines. My Fiero had a Code 32 and the problem was a blocked vacum line.
I could have saved $105 if I checked the lines first.
99ssconv
11-20-2003, 10:41 PM
if all checks good then check calibration update for false code 32
blackhawk5177
02-07-2004, 09:43 PM
have replaced valve and solenoid , vacum lines are all clear ..vacun is high and steady. i changed o2 sensor,fuel pressure regulator and map sensor. The only thing i have not changed is the idle air control valve and the knock sensor
GMMerlin
02-08-2004, 08:02 AM
I did dig up an old bulletin that may help.
DIAGNOSTIC TROUBLE CODE 32 WHILE UNDER HEAVY LOAD #57-65-09 - (12/01/1995)
REVISION: 12/06/95
THIS BULLETIN IS BEING UPDATED TO ADD 1994 AUTOMATIC TRANSMISSION PART NUMBERS. ----------------------------------------------------------------------
SUBJECT: DIAGNOSTIC TROUBLE CODE 32 WHILE UNDER HEAVY LOAD (INSTALL NEW MEM-CAL)
MODELS: 1994-95 CHEVROLET AND GMC TRUCK C/K, G AND P MODELS WITH 7.4L ENGINE (VIN N - RPO L19)
CONDITION:
SOME OWNERS MAY COMMENT OF A CEL WHILE UNDER A HEAVY LOAD SUCH AS TOWING. THE ECM WILL HAVE A STORED DTC 32.
CAUSE:
UNDER CERTAIN DRIVING CONDITIONS, USUALLY WHILE TOWING, THE EGR IS COMMANDED TO CYCLE OFF AND ON RAPIDLY. THIS CAN CAUSE THE EGR TO APPEAR UNRESPONSIVE TO ECM.
CORRECTION:
THE CALIBRATION HAS BEEN CHANGED TO BECOME MORE ROBUST WITH RESPECT TO THE CONDITIONS CAUSING THE EGR TO RAPIDLY CYCLE. INSTALL THE APPROPRIATE MEM-CAL FROM THE CHARTS BELOW:
1994 MODEL YEAR BROAD- VEHICLE OLD MEM-CAL NEW CAST GVW/ MODEL SCAN ID PART# SCAN ID CODE TRANS. FUEL TYPE OTHER ---------------------------------------------------------------------- C3 9465 16220284 0285 BPRH MAN. UNLEADED 15,000 GVW 4675 (RPO C5B) ---------------------------------------------------------------------- C3 9475 16220287 0295 BPRJ MAN. UNLEADED (15,000 GVW 4685 ---------------------------------------------------------------------- C2 9475 16220287 0295 BPRJ MAN. UNLEADED (15,000 GVW K2,K3 4685 ---------------------------------------------------------------------- C2,C3 8045 16231250 1265 BSRC AUTO. UNLEADED (15,000 GVW K2,K3 ---------------------------------------------------------------------- C3 8075 16231256 1285 BSRF AUTO. UNLEADED 15,000 GVW (RPO C5B) ---------------------------------------------------------------------- G3 8045 16231250 1265 BSRC AUTO. UNLEADED G3 NOT GOVERNED ---------------------------------------------------------------------- P3 8075 16231256 1285 BSRF AUTO. UNLEADED ---------------------------------------------------------------------- C2,C3 8055 16231252 1275 BSRD AUTO. LEADED K2,K3 (EXPORT) ---------------------------------------------------------------------- P3 8035 16231248 1255 BSRB AUTO. LEADED (EXPORT) ---------------------------------------------------------------------- C2,C3 9485 16226250 6175 BRCZ MAN. LEADED K2,K3 4695 (EXPORT) 1225 ----------------------------------------------------------------------
1995 MODEL YEAR
BROAD- VEHICLE OLD MEM-CAL NEW CAST GVW/ MODEL SCAN ID PART# SCAN ID CODE TRANS. FUEL TYPE OTHER ---------------------------------------------------------------------- C3 9465 16220284 0285 BPRH MAN. UNLEADED 15,000 GVW 4675 (RPO C5B) ---------------------------------------------------------------------- C3 9475 16220287 0295 BPRJ MAN. UNLEADED (15,000 GVW 4685 ---------------------------------------------------------------------- C2 9475 16220287 0295 BPRJ MAN. UNLEADED (15,000 GVW K2,K3 4685 ---------------------------------------------------------------------- C2,C3 9495 16220290 0305 BPRK AUTO. UNLEADED K2,K3 0645 ---------------------------------------------------------------------- G3 9495 16220290 0305 BPRK AUTO. UNLEADED G3 NOT 0645 GOVERNED ---------------------------------------------------------------------- G3 9505 16220292 0315 BPRL AUTO. UNLEADED GOVERNED (RPO 9C2) ---------------------------------------------------------------------- C3 9515 16220294 0325 BPRM AUTO. UNLEADED 15,000 GVW 0655 (RPO C5B) ---------------------------------------------------------------------- P3 9515 16220294 0325 BPRM AUTO. UNLEADED 0655 ---------------------------------------------------------------------- C2,C3 9535 16225576 5575 BRCU AUTO. LEADED K2,K3 (EXPORT) ---------------------------------------------------------------------- P3 9525 16225578 5585 BRCW AUTO. LEADED 0695 (EXPORT) ---------------------------------------------------------------------- C2,C3 9485 16226250 6175 BRCZ MAN. LEADED K2,K3 4695 (EXPORT) 1225 ----------------------------------------------------------------------
