my 91 acura just lost its tranny because my gf slammed it into gear while i was in neutral so my friend is selling me a 95 neon w/ a supercharger because i am desperate for a newer car, the ac is barely driveable, and he says that all it needs is a timing belt. if he snapped the timing belt does this mean that a valve is likely to be blown too or no? He only wants a couple hundred for the car but i dont wanna have to put a new engine in it, so how can i check the engine to make sure there are no other problems and what are the chances of a valve being f***ed on it ? I need to know asap so thanks for your help
All I know is that when I broke the timing belt in my 95 I bent 14 of the 16 valves. I did not have to replace the block I did how ever have to replace the head. I got a good used head at a salvage yard for $75 the main cost was the price of the valves and the labor to do the head work.
If you timing belt had snapped, it would not run....
Also, if the valves were bent, chances are the car would backfire and make a noise like a rifle being discharged. If it's a freind?, change the plugs, ten bucks, the fuel and air filter, and put in a can of injector cleaner. Freind or not, it could be expensive to fix.
