TRD engine240-kid 10-23-2003, 11:34 PM Is there such thing as an 4AGZE TRD Race Engine? AceNZ_20v4AGE 10-24-2003, 07:18 PM hard question... but I dont think there is, there is TRD parts for them but TRD only seamed to mod the 4age 1.6's for racing since they like to hold high revs Toymaniac 10-24-2003, 08:49 PM not that i know of.... but there is a 16 valves blue top that is used in atlantic formula 249hp tunned by TRD.... N1 engines are tunned by TRD i think they are silvertops (realy not shure of that..) and of course the 503-E based on the 3sgte and good for 1000hp+.... wich is used in pikes peek celica and other races.... TrvlynAlec 10-25-2003, 05:45 PM You are probably thinking of the 1.6L 4age Formula Atlantic race engine. It puts out 250hp, and the block is off a 4agze. They do this becuase the 4agze block is alot stronger, and can hold more hp. However it is a n/a engine. Toymaniac 10-25-2003, 06:26 PM the atlantic engine is NOT a 4agze block i'm 110% sure of that its is a 4age blue top block even if the 4agze is stronger i'm positiv that it is a blue top block that is used in the atlantic engine yes some built with the red top or 4agze block but not in the official atlantic championship :iceslolan AceNZ_20v4AGE 10-26-2003, 04:57 AM yep the N1 engine is silvertop (is it the ones they use in formula toyota? they were silvertops TRD tuned) the gze block is the same block as the 20v's but I dont think it was used in the atlantic engine robbiec 10-27-2003, 04:49 AM guyz all 4ag engines from 87/88-93 (in australia) use the same 7 rib block with the same rods n the same crank differences lie in the head n pistons only Toymaniac 10-27-2003, 07:15 AM sorry to argue a little but the 20v and the gze do not have the same block ... the 20 v as the same block as the red top (130hp) the gze is a different block and the blue top is different so there is blue top gze and 20v/redtop blocks i might be mistaken? robbiec 10-28-2003, 02:28 AM well im affraid to say u r wrong all three motors share the 7 strenghtening ribbed block all have the same crank n im pretty sure the have the same rods as well thats in the 100kw map 4age the ae92 onwards 4agze n both 20v engine early 4age only had the 3 rib block look it up or ask knowledgable people i have been reaserching the engine for yrs so yeah i know a bit AceNZ_20v4AGE 10-28-2003, 06:13 AM well... I own a silvertop, and here in NZ the AE101 and AE111 is very common so were to start hmm... ok, 20v's and gze both use the 7rib block 20v's have lighter blanced rods over gze stronger heavyer ones gze has semi forged pistons (some forged) cranks the same (I think) and then there is the heads.... also the gze runs a heavyer gearbox to handle the power down low better and in most cases came factory with LSD in short the 20v internals are lightend and blanced for a high reving n/a engine, while the gze has the same block but heavyer bottom end to handle the pressure better my engine bay :D http://www.angelfire.com/mt/AceSniper/pic/engin.jpg some AE101 info http://www.angelfire.com/mt/AceSniper/ae101.html XentricAE92 12-05-2003, 04:19 AM Check out the engines on www.todaracing.com (http://www.todaracing.com) vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
