# on my turboTurboCivic 12-08-2001, 09:11 PM Wassup i got a new name now but 1. I heard u can run up to 8# boost with the greddy on stock internals of the D16Z6, im running 7 # right now 2. What i need to run 8# i got a fuel regulator dont tink a fuel pump is required?> 3. Im gettin a turbo head put on my car right now what kind of tuning is needed>? pvang31019 12-09-2001, 01:43 AM all you needis to turn it up.....if you're gonna be around 10lbs or so, then I suggest you get a vortech or cartech FMU, 310cc injectors, and a bigger pump(or an inline fuel pump)... TurboCivic 12-09-2001, 09:21 PM Turn up what(The pressure from my fuel regulator?) I dont think u can run 10psi on stock pistons and rods!!!Or ur likely to be pushing things to the limits. pvang31019 12-09-2001, 09:52 PM I menat, get a mbc and turn up the boost...and trust me, I've had experince running 20lbs untuned with stock fuel system in a SOHC motor...it only lasted a week, but it ran strong. If we had bigger injectors to tune it with, that motor woulda still be singing right now. DO NOT BELIEVE THE MYTH ABOUT HONDA MOTORS BEING WEAK PAST 10LBS!!!!!!!!!IT'S ALL HYPE!!!!!! AGAIN I SAY, TUNING IS THE KEY TO A HAPPY ENDING!!!!!!!!!! Automotive Network, Inc., Copyright ©2012
