Programming 1998 Avalon Remote FOBpp1111 10-23-2003, 07:03 PM I have on FOB for my 1998 Avalon XLS and I given one that matched. Same match and manufacture. I need someone to show me how to program the FOB to synchronize with each other and the Avalon's remote system pp1111 bestwinter 12-09-2003, 01:22 AM I have 1996 avalon xls. Also need to know how to program wireless remote( have option open trunk, lock, and unlock). thank. Email saigonla@yahoo.com Robert50 12-12-2003, 11:16 AM Does anyone know how to program a remote FOB for a 1995 Toyota Avalon? stephensclan 09-26-2004, 12:19 AM Toyota has so many different type of alarms that do not have interchangeable remotes that they even put out a TSB on the subject. http://rav4world.com/tsb/EL010-01.pdf If you can then identify the system, you may be able to find the TSB with the correct instructions. jck1 12-17-2004, 10:23 AM I got weary looking for this, so once I found it, I thought it would be good to share it with you. I tried this out on my 1998 Avalon XLS, and it worked great. Those batteries don't last forever, and when you have to replace one, you shouln't have to pay a lot of money to get the remotes reprogrammed, too. Here is some background information: FCC ID:HYQ1512Y CAN: 1551 102578 RSS-210 DENSO 1. Open driver's door. 2. Insert and remove key from ignition. 3. Lock and unlock power door locks 5 times. 4. Close driver's door and reopen it. 5. Lock and unlock power door locks 5 times. 6. Insert key and turn it on and off 2 times without cranking the engine, then pull the key out. The locks should lock and unlock automatically, one time. 7. Press both the lock and unlock buttons at the same time. 8. Press the lock button once. The locks should lock and unlock automatically, one time. If the locks lock and unlock twice, it didn't work. Repeat steps 7 and 8. If you wait too long between steps, you need to start over. If you are programming more than one remote, just repeat steps 7 and 8 immediately after you finish steps 7 and 8 with the first remote. This way, they both obtain the same code. When I performed these steps, at first it seemed to work, then it seemed like something was wrong with the programming on one of the remotes because it wasn't unlocking the doors or the trunk. I'm not sure what I did next, but after a minute or so, it worked as well as the first one. I can't explain why. Maybe I had to shut the driver's door first, but the instructions did not say this. tfeld 12-21-2004, 08:22 AM That procedure will work as written on my 2001, but step #6 should be only one time, not two. One time sets the ECU to "add mode" which is what you want to do if you're just making a new fob work. tsei 08-11-2006, 09:45 PM who ever put this up, a big thanks to you. it was very useful. ty again. cheers. Automotive Network, Inc., Copyright ©2012
