JrscOz 12-08-2001, 04:00 AM Hey all, does anyone know all the details of the Jackson Racing SC for the JDM B16A? What boost etc. Can the pulleys be modified to give more boost. If yes how. Just wateva u no... Trinity 12-08-2001, 01:08 PM i think you can only get 9 lbs out of them and here is a page with a dyno chart, just look up the 99 si http://www.jacksonracing.com/pages/details/detailspage_h.html delsolguy 12-08-2001, 01:16 PM I believe Jackson sells an 8 psi pulley. Endyn sells better ones. Anything over 8 psi and...well...I've heard bad things can happen. The JRSC is good, but overpriced. It all depends on what you want in your car. madtownhonda 12-08-2001, 03:28 PM I know a guy that's running 10lbs daily on a EX..thing pulls hard too....but the chargers are fuckin loud...sounds like a screaming banshee from hell:lol2: sparq 12-08-2001, 03:32 PM Originally posted by madtownhonda I know a guy that's running 10lbs daily on a EX..thing pulls hard too....but the chargers are fuckin loud...sounds like a screaming banshee from hell:lol2: ...and a turbo doesnt? :devil: Trinity 12-08-2001, 03:42 PM i personally like the vortech one but it is like a belt driven turbo really. madtownhonda 12-08-2001, 03:52 PM Originally posted by sparq ...and a turbo doesnt? :devil: hehe...different sound though foo:lol2: sparq 12-08-2001, 04:43 PM Originally posted by madtownhonda hehe...different sound though foo:lol2: Dont make me hurt you! :crying: :aug2: madtownhonda 12-08-2001, 05:50 PM Originally posted by sparq Dont make me hurt you! :crying: :aug2: :flipa: :lol2: ric 12-09-2001, 12:16 AM it shoudl be the same as any us civic si or canadian sir. stock pulley is 6.5 psi and the unpgrade kit which is a bigger pulley for 8psi and a fuel pump to up the pressure. upgrading past 8 psi should only be done if you know what your doing. detonation managment becomes and issue with the the high compression of a b16 on even 93 octane pump gas when you go past 8 psi because of dramatically increased intake charge temps. some massive ignition retardation or some method of cooling will be necessary, the water injection is a joke of you ask me so the next best thing would be to have the charger reworked to better tolerances so it flows better and creates less heat during compression. next problem would be fuel, your gonna have to have your pressure way to high so your gonna have to get some bigger injectors (you would have to with a turbo too). just raising the pressure higher and higher dependent on boost is only a half ass patch to a problem and will eventually lead to problems of its own. the stock fuel pump (of an SI) i believe texan said is capable of handling 400hp at stock pressures. not to mention the piggybacks your gonna need to control this shit to make a long story short if you plan on staying around the 6-8 psi level then the jrsc is ok i guess. i would still consider a small turbo like the 15g or 16g kit from greddy as it is much easier to maintain acceptable intake charge temps and essentially create more power with less boost, and you can adjust the turbo WAY more easily then the jrsc to meet different driving conditions like the change from street to track. one thing people often overlook is you can alter a turbo around a motor but you have to alter a motor around a supercharger. if turbo lag is getting you down then while your replacing your stock clutch which you'll probably have to, throw on a lightened flywheel and have your turbo manifold extrude honed. well im boring myself so im gonna go now, adios madtownhonda 12-09-2001, 01:00 AM here you go, this are the mods on the car...guy knows what he is doing:D Engine: Jackson Racing Supercharger -ported and polished intake manifold -ported and polished S-tube -ported and polished bypass valve -ASP 3.25" pulley in red AEM 2.75" Cold Air Intake Otherwise Stock D16Y8 SOHC Vtec Fuel: Walbro High Flow Fuel Pump RC 310cc injectors AEM FPR Cartech 2020 FMU Timing and Ignition: MSD 6BTM Blaster 3 Coil MSD 8.5mm wires MSD Cap J&S Ultra Safeguard Exhaust Thermal R&D Stainless Exhaust DC Sports 4-2-1 Ceramic Header Suspension Progress Competition Coil-OVers Progress Camber Kit Suspension Tech Matched Sway Bars 16" Rota Circuit 8 Wheels Dunlop SP9000 Tires Car has been corner weighted Brakes AEM BiG Front Brake Conversion AEM Rear Disc Conversion Motul Fluid Transmission Quaife ATB Limited Slip Diff Fidanza Aluminum Flywheel Clutchmasters Stage III Clutch LSR Short Shifter Interior Autometer Sport Comp Guages -Fuel Pressure -Boost/Vac -A/F ratio -Triple Pillar mount Autometer Shift Light Aluminum Dash Kit Exterior Full Honda OEM Body Kit ric 12-09-2001, 01:26 AM i'd say so. Oz 12-10-2001, 03:32 AM I am after a daily driveable, quality, reliable power increase and don't really want a turbo. This seems the way to go. What other B16A SC kits are there? Thanks for the info, all. delsolguy 12-10-2001, 08:06 AM The other sc kit that I know of is the Vortech kit. Like Trinity said, it's really just a belt driven turbo. The kit is like close to $4000 USD...I'd rather have a turbo over this. slvr-bullet 01-09-2002, 12:21 PM Originally posted by madtownhonda -ASP 3.25" pulley in red Is the ASP pulley from the crank or from the nose of the blower? Where can I get one? How much? Thanks slvr-bullet 01-11-2002, 10:35 AM TTT Automotive Network, Inc., Copyright ©2012
