Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Probe
Old 10-19-2003, 06:27 PM   #1
joe morgan
joe morgan Normal reputation
automatic seat belt
92 Probe. automatic seat belt somtimes works but mostly wont reatract to the open position. I understand thiers a processor that controlls this but what about switchs? Cant seem to find any information. Can you help?
joe morgan is offline   Reply With Quote
Old 12-14-2003, 12:20 PM   #2
biggs
biggs Normal reputation
The seat belt retractor is located behind the rear side panels. This requires removal of the rear seat bottom, door sill trim. trim around the door. You should call your local dealer, I think ford has a lifetime warrantee on belts. What your problem is the seatbelt retractor works off cables and they get worn and jam. The door jam switch is what makes these work.
Good luck.
biggs is offline   Reply With Quote
Old 05-28-2004, 08:56 PM   #3
garyrace
garyrace Normal reputation
Automatic Seat Belt Erratic behavior
If your seat belts are behaving erraticaly, stop midway or any other way do not opperate correctly. Measure the Green and Black wire in the black pulg to the controll module located in the Left rear seat Panel . This wire comes from the fuel shut off switch in the trunk. It should measure OPEN or ZERO Ohms on your OHM meter. If it reads any resistance at all your fuel shut off switch has resistance from ground to the seat belt controll module, current will flow to it and the module will get false signals causing erratic behaviour.
I had to use a blunt screw drive to force the Red reset switch back to an "OPEN" condition. The switch is likely old and probable needs replacing but this did eliminate a false signal to the control module.
Gary
garyrace is offline   Reply With Quote
Bookmarks
Google
Web AF
