Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 10-18-2003, 10:00 AM   #1
goatman794
goatman794 Normal reputation
reprogamming keyless remote
i have a 2000 chevy astro van and i need to reprogram the remote any suggestion on how to do this????
goatman794 is offline   Reply With Quote
Old 10-18-2003, 10:16 AM   #2
BOOZER
BOOZER Normal reputation
Re: reprogamming keyless remote
Document ID# 605202
2000 Chevrolet/Geo Astro - 2WD
Transmitter Synchronization
Due to the security method used by the remote keyless entry (RKE) system, the transmitter may have to be synchronized. The RKE transmitter does not send the same signal twice to the receiver because the receiver will not respond to the same signal twice. This prevents the signal from being recorded and retransmitted.
Synchronization will be necessary if one or more of the following conditions apply:
The transmitter battery is very weak.
The transmitter is replaced.
The vehicle battery is very weak.
The vehicle battery is replaced.
The vehicle battery is disconnected.
Synchronize the transmitter with the receiver as follows:
While standing close to the vehicle, simultaneously press and hold the LOCK and UNLOCK buttons on the transmitter for 7 seconds.
The door locks should cycle in order to confirm synchronization.
Document ID# 605202
BOOZER is offline   Reply With Quote
Old 10-18-2003, 10:27 PM   #3
goatman794
Re: Re: reprogamming keyless remote
Originally Posted by BOOZER
Document ID# 605202
Document ID# 605202
thanks i tried that but it did not work. the remote i have was never set for this vehicle maybe it needs to be programmed a differant way any suggestions
Old 10-19-2003, 05:53 AM   #4
GMMerlin
I know stuff
GMMerlin's Avatar
GMMerlin Normal reputation
Re: Re: Re: reprogamming keyless remote
You may have the wrong part number remote.
If you have the original remote that came with the vehicle, check the part number on the back. All the remotes should have the same number.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
GMMerlin is offline   Reply With Quote
Bookmarks
Google
Web AF
