Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 10-18-2003, 09:15 AM   #1
hunter429
hunter429 Normal reputation
S-10 quitting or not starting
I have a 96 S-10. For over a year it has had a problem, occurring only once every couple months until recently, where it would either cut out and quit, or wouldn't start. Turns over normal, no spark and I think no fuel (when we pulled a spark plug it wasn't firing or wet). Strange thing about this is, after the truck sits for a little as maybe ten minutes, it starts right up and might run fine for months. Recently however this has starting occurring every few days. I thought I heard a clicking in the right front around the glove box a couple times before it started back up, but I can't be sure about that (I'm lost with any vehicle newer than about '85!) We replaced the ignition module the first time this happened, just on a wild guess, and it ran fine for a long time, but I know now that actually wasn't the problem.
Any ideas. I thought about replacing the ignition switch (wild guess #2). Something is shutting off, or breaking, and resetting is my hunch but beyond that I'm lost.
hunter429 is offline   Reply With Quote
Old 10-18-2003, 02:43 PM   #2
Pickup guy
Pickup guy Normal reputation
Re: S-10 quitting or not starting
Your ECM could and probably is located up under the dash behind your glove box. You might want to have the checked out-it controls everything. If its bad-might replace it with one from a recycling yard-lots cheaper.
Pickup guy is offline   Reply With Quote
Old 10-18-2003, 03:41 PM   #3
BOOZER
BOOZER Normal reputation
Hunter429, not a lot of info to work with here, like the odvious, what motor??? 2.2/4.3 ??? Pickup guy
said ECM, truck has no ECM, it's a PCM on this truck, with OBD2 & it's located under hood on the coolant overflow tank. Dont try to replace this as a
shot in the dark repair. PCM has to be flashed at a dealer/not cheap, even if you can get the part cheap.
ANY CODES SET?
AFTER STALL, CYCLE KEY, F/P SHOULD RUN 5-SECONDS- DOES IT??
FUEL PRESSURE, ANY, ABOVE MINIMUM??
SPARK??
CONDITIONS FOR STALL, THE SAME ??
WHEN, IDLE,TURNING,BRAKING,HOT,COLD
check F/P relay or crank sensor first.
BOOZER is offline   Reply With Quote
Old 10-18-2003, 07:04 PM   #4
hunter429
Re: Re: S-10 quitting or not starting
ANY CODES SET?
SPARK??
I hope you'll forgive me for being an idiot on modern auto electronics. I had it at Chevy last spring and of course couldn't get it to do it. Had it towed in and took it off the truck and it started right up. Happened so rarely I was just living with it. When it goes when driving, the last two times, I get a flurry of clicking in the relays in the glove box, flashing of lights on the dashboard, lurching, then dead, but with all other power working. Did it today. Ten minutes wait, trying it every couple minutes, then it runs. No connection to hot/cold, wet/dry.
I have not done anything with codes.
Old 10-19-2003, 07:17 AM   #5
GMMerlin
I know stuff
GMMerlin's Avatar
GMMerlin Normal reputation
Re: Re: Re: S-10 quitting or not starting
Most likely senerio is that you have an ignition switch that has failed.
Have seen many trucks with the same symptoms fixed with replacing the switch.
(like BOOZER, I like to see some diagnostics done before recommending a part be changed, but I feel fairly confident that a switch will fix your problem)
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
GMMerlin is offline   Reply With Quote
Old 10-19-2003, 07:32 PM   #6
hunter429
Re: Re: Re: Re: S-10 quitting or not starting
I can add these bits of information - when the truck is in the NOT starting condition (turning over no spark), when I turn on the ignition key I hear one click over in the relays in the glove box. When it is starting OK, and I turn on the ignition key, I hear TWO clicks.
Second bit of information - the second time it quit this morning I did a little frontier justice and gave the top of the steering column a good thump with my fist (made me feel better) AND it hasn't quit since - I think I'm going to throw in an ignition switch (what's 80 bucks nowadays? ) and go from there. If that doesn't work I'll just have to take my truck and my wallet down to Chevy and let them have at it.
I appreciate everybody's help!
Old 12-02-2003, 11:47 AM   #7
Ralph Lawson
Ralph Lawson Normal reputation
Howdy...my son's S10 does this very same thing. I keep blaming it on the fuel filter, but after a couple Wix @$14 doesn't seem to be the problem. Did changing out the switch fix your problem? The truck is a 4 cylinder, 1986 runs fine except it just quits running, wait awhile and it'll start up. Any help would be appreciated, I'm getting ready to take it to the garage...help$$$
Ralph Lawson is offline   Reply With Quote
Old 12-04-2003, 11:50 AM   #8
nightdriver09
nightdriver09 Normal reputation
Hey folks: Nobody said anything about blowing fuses
I was talking to a friend last night about his Toy pu
and he said a friend of his had just borrowed my
friend's mom's '89 s-10, drove it 12 miles and it just
quit on a main street. My friend went over and put
in a new fuse in the ECM-I socket and it blew also.
As of 8 pm last night after 1 hour charge at 5 amps
the battery is still only at 12.56 volts and the head-
lights won't come on. It sounds like the same problem but none of you mention a blown fuse. Are
we on the same page here?
nightdriver09 is offline   Reply With Quote
Old 02-06-2004, 12:42 AM   #9
bj126821
bj126821 Normal reputation
My 96 s-10 is doing the samething now ,,,did replacing the ingnitoin switch help,,,PLEASE let me know.
bj126821 is offline   Reply With Quote
Old 02-06-2004, 02:10 PM   #10
nightdriver09
On my Friend's '89 that was caused by the airhat
shorting out an injector lead. You have MPI. Check
to see if you have any blown fuses, ECMI or ECMB.
This is getting to look like a fuel pump relay, which
could be caused by a short in the elec. system.
Old 02-16-2004, 11:10 AM   #11
NovaRod
NovaRod Normal reputation
I'm also trying to nail down this type of an S10 problem (which seems to be a common problem).
Look at this thread and let me know if you find out anything else. Thanks!
http://www.automotiveforums.com/vbul...d.php?t=188705
NovaRod is offline   Reply With Quote
Old 03-31-2004, 02:54 PM   #12
holysmokesareforre
holysmokesareforre Normal reputation
My s15 keeps blowin ecm fuse as soon as truck starts for a second,need help too
holysmokesareforre is offline   Reply With Quote
Old 03-31-2004, 02:56 PM   #13
holysmokesareforre
My s15 2.6 keeps blowin ecm fuse,any ideas tried alot........
Old 03-31-2004, 07:18 PM   #14
tinkerer
tinkerer Normal reputation
Okay guys this may not apply here but I am going to mention it anyway. Since iI am not sure if they ever put one in the s-10's or not. My corsica when i bought it had similar problems and the garages could not figure it out. They replaced fuel pumps, computers, ignition modules, coil packs (Distributorless ignition on this car so if you have a distributor it most likely does not apply lol) and checked wiring and fuses and so on totaling around 2000$ my parents sunk into it in garage bills. So they got sick of it and sold it to me for 100$ 8 years ago. Well i being the cheap S.O.B. I am went to the junkyard and got a couple of each of the previosly listed parts and went home and started trying things. Well 1 month later i bought a crankshaft sensor put it in and drove the car for 2 years then had to replace it again. And had to do so every 2 years till i bought my Jimmy and quit driving it. If nothing else this may help people reading the forum who have the same problem with another car the own and may be of help to them.
tinkerer is offline   Reply With Quote
Old 04-06-2004, 11:24 PM   #15
nightdriver09
To Holy Smokes, It sounds like you do have a shorted wire. One thing, have you steamed off the engine lately?. Something could be moved and making contact. Try to remember anything that was done to the engine, and look in that area for mis-routed wires. I replaced the lower ignition switch on my friend's but it was not the cause. Let us know what the real problem was, non-starting seems to be getting more common on these trucks.
Bookmarks
Google
Web AF
