The Honda S2000JD 12-08-2000, 10:39 PM So what do people think of the Honda S2000? I am impressed that with this car Honda was able to do what they have failed to do so many other times. For starters, they have finally produced a car with a perfect 50/50 front/rear weight distribution. It also remains (with the exception of the NSX) the only rear-wheel-drive sports car that Honda makes. They have managed to edge out the Porsche Boxster and the BMW M Roadster in many respects. I do have issues with its engine, however. As technologically advanced as it is, it is limited in its durability. Other Honda VTEC engines (examples: the Civic Si's B16A, the Integra GS-R's B18C, the Prelude's H22A) have the ability to withstand fairly high levels of boost. Of the twelve fastest Hondas in the world (in terms of drag racing), I believe two thirds of them have either the B18C or the H22A powerplant. These engines can be rebuilt with lower compression, forged aluminum pistons and connecting rods, iron sleeves, fueled with larger fuel injectors, and protected with block guards and other forms of safe-guarding to perform to a limited degree of reliability under the stresses of 25 PSI of boost or more even. I have my doubts however, about the S2000 engine's ability to perform up to the edge of this envelope, due to the fact the it pushes the limits so much as is, naturally-aspirating 240 horsepower up to a 9,000-rpm redline. Additionally, I have heard many critical commentaries addressing the engine's lack of low end torque. Its performance capabilities cannot be denied as being anything short of astounding, but, its adaptability in terms of fitting into the routines of a daily driving car, coupled with the more fragile nature of its high-revving capabilities makes me withhold the praise for it that so many generously adorn on it. Honda needs to figure out how to take the engine's capabilities and revamp it into a more-well-rounded package. enzo@af 12-09-2000, 11:10 PM As for building engines with aftermarket in mind, I don't think Honda really cares. If they were desirous of building cars with the intent of the owner's modifying them, I don't think they would've made the new Civic larger, heavier, and with a flat rear floor (and thus lower exhaust pipes, just ready to be scraped). The S2000 is running with 2 liters, so low torque numbers aren't that surprising. I would assume (without any basis) that with a 9,000 RPM redline low end torque problems could be averted by not letting the RPM's drop. ---------- "Ferrari isn't a car, it's a lifestyle" -Enzo Ferrari. JD 12-10-2000, 04:06 PM You're dead right, Honda does seem to be moving the Civic out of reach for the aftermarket tuner, much to the dismay of many enthusiast Honda owners. Apparently they have moved the catalytic converter closer to the exhaust manifold, situating it so it is almost incorporated into it, making the exhaust system more difficult to work with for tuners. As for the S2000, Honda is reportedly trying to work on the engine's low torque issues, as yes, keeping the rpm needle jumping will supply the power needed, but it also makes the car more difficult to live with, particularly as a daily driver, with little "stop light" power. They were able to engineer more torque into the bottom end of the 3.2TL's power delivery without too drastically altering the engine. Maybe some of the principles applied there will work on the S2000. VTEC V6 01-01-2001, 10:06 PM if u shift at 5k rpms u will hit 60 in 11 seconds. thas pretty bad that all the power is way way up there in the power band ppl will be thinkin ur showing off and speeding when ur just trying to get up to speed wit the redline @9000rpm i think a supercharger will help out the s2000 alot especially wit low end torque and then it will be able to keep up wit corvettes, m3's, etc. ---------- 00 Honda Accord coupe EX V6 SS aem cai, WW 3-piece midwing, clears enzo@af 01-03-2001, 05:12 AM Also, just because power is down doesn't mean it isn't a good sports car. In the days of old sports cars were small, quick, tight handling cars. They would get killed in drag races, but they are a blast to drive. Straight line performance isn't everything. ---------- "Ferrari isn't a car, it's a lifestyle" -Enzo Ferrari. JD@af 01-06-2001, 02:31 PM enzo You're absolutely right, and its handling is top notch. But to market this car as to be conceived as a "relative" mass production car, it must function practically as a daily driver. Period. They aren't building this car as a supercar that is expected to be purchased by racing teams to use as their new platform (which, for example, is the intended buying group for the new Saleen S7), but as a sports car, probably for warm weather use (as Honda has finally developed a non-front-wheel-drive car), but still with daily driving practices supposedly integrated into the design parameters. And frankly, if it takes 11 seconds to hit 60 mph shifting at 5,000 rpms, I think Honda has missed the boat. Adam 01-27-2001, 02:13 PM I think it's awesome in looks, but i don't know much about it. HXMan 02-04-2001, 10:51 PM That car was my reason for going to collage....I wanted to make enough money to be able to afford one. But now after hearing about the cars awful low rpm performance I am not sure I would like one. 0-60 in 11sec if not shifting over 5000rpms? WTF is that! Sure, the car has only 2 liters in displacement but my civic only has 1.6 liters and it can probably go 0-60 in 11 seconds shifting at 5 grand. I know the car was optimized for top end power but I would not want to be pounding the shit out of my car all the time just to get up to speed.....has anyone heard that old saying TOO allways talks about. RPM=Ruins Peoples motors. I ask how long is a S2000 motor going to last if it hits 7000rpms quite a few times daily? I do love the way the car looks, and the high end is great, but if I was to buy one I think honda would have to do some more work and definitly boost up the low end torque. Anyone know if the S2000 uses intake butterflies like the GSR.....maybe the honda engineers could adapt that to the S2000 to produce some more low end torque......of course they could lower the compression and put a turbo on there too! JD@af 02-05-2001, 09:33 AM In fact, with the S2000, for the first time Honda is really going back to the drawing boards trying very hard and working long, late hours trying to devise methods of bulding engines utilizing the VTEC high-rpm power, while retaining more of the low rpm power that VTEC engines usually lack. The most obvious solution, increase displacement, is being considered of course, but Honda is trying to work around this.. naturally a big challenge. But the complaints of the low end torque in the S2000 are being filed so completely across the board that Honda engineers are taking it very seriously. I too wish that Honda would just stick a turbo on there and sell the car with a factory, Honda-supported FI system, but I doubt that we'll see anything like that (at least not in North America). But hey, we can dream and hope, and pray that Honda has a few other tricks up their proverbial sleeves to utilize complete cam timing changes with rpm to produce the low end torque not found in conjunction with the VTEC system to date. HXMan 02-05-2001, 10:00 AM Maybe they can incorperate the new VTEC-I technology and vary the cam timing. I believe that the S2000 already has the three stage VTEC in it, I just can't see why the torque is so weak in the low end...well I kinda know why, but I mean with 2.0 liters there should still be something there. Maybe they will have to loose a little high end power for some low end torque....who know's. But I do have faith in the honda engineers. Look at the new K series engines coming in the new integra, they got some torque, and plenty of high end power! JD@af 02-05-2001, 06:18 PM K series engines? Never heard of them! Wow, I figured that the new Integra had a B18C, basically with a stroker to bump the displacement to 2.0 liters. I gotta get on the ball. As for the S2000, yes, it does feature the three-stage VTEC system, but its lack of low end torque is related to its excessive overlap of cams (i.e. the intake and exhaust cams are open simultaneously, which actually helps create a pressurized flow that allows more air to pass through the engine. There is suction created by the fact that the exhaust valves open, removing air, while the intake valves are still open, therefore drawing more air into the cylinders). This is great for high rpm power and breathing, but a real enemy of low end torque and power (and an enemy of forced induction as well). This also helps illustrate the one-sided intended usages of the S2000 engine, and one of primary challenges facing Honda engineers. HXMan, thanks for the info, and if you have any links or other info sources for the RS-X, please share. Thanks! -JD texan 02-06-2001, 05:30 AM JD- http://www.tamparacing.com/ubb-import/Forum4/HTML/000087.html The most info I've seen on it is in that post. JD@af 02-06-2001, 05:47 AM Much obliged, tex. I like the timing chain (about damn time somebody did away with a timing belt, and at least one-upped it for a chain), but naturally I do not like a single pulley that controls both of the pulleys that are keyed on to the cams. I see Honda's reasoning for doing this, but once again, this move takes away tunability. What remains to be seen for the general public is whether the i-VTEC system will be able to change the timing significantly enough to produce significant gains at low rpms. It's like the whole issue of "on-boost performance versus off-boost." Without deferring to displacement or FI, this remains a formidable challenge to Honda engine design parameters. Hell, if Honda can solve this riddle, I won't even want to play with my cam timing. I will be eagerly awaiting a chance to see that production version two months from now in NYC. texan 02-06-2001, 06:29 AM JD- please hit me up on my email (ferrari@omnicolor.com) or AIM (texan245) ASAP! Thanks. kepone 02-09-2001, 01:14 AM Originally posted by VTEC V6 if u shift at 5k rpms u will hit 60 in 11 seconds. thas pretty bad that all the power is way way up there in the power band this is a statement that always pisses me off.. its the biggest bullshit line ive ever heard.. hey, guess what? if you shift a viper 4 grand below its redline, its 0-60 will probably close to 11 sec too.. does that make it a bad car? umm.. no.. the fact that the s2000 is as docile as a civic during normal driving is an advantage, not a weakness.. why cant people see that? they have their econobox for the workdays and a full out track beast for the weekends.. i mean, what more could you ask for? ill admit that the torque is a bit lacking, but the car works.. it gets the job done.. and if you dont have the skill or balls to keep the car in its powerband when you want to race, dont go knocking honda for that.. its that simple.. now, onto this reliability thing.. if you go run 25 lbs of boost through ANY stock engine out there.. and that includes ALL honda engines and EVERY other engine in the world, you're going to damage/ destroy the engine.. any engine thats taking high boost levels, is going to be heavily modded internally. ALL of the fastest civics/integras etc etc using the b16, b18, or h22 are internally modded to handle the boost, and they all have lower than stock compression.. so to say that the s2000 cant do the same just shows a general lack of knowledge... just like any engine, you can upgrade the head gaskets, pistons, rods, rings, valves, whatever you want to affect the compression of the s2000's engine.. the only problem is that there isnt much of an aftermarket for it yet ( because its only a year old ).. comptech has a supercharger out for the s2000 now, that makes the engine put out 340crank hp, with stock internals.. so sorry, the s2000 will have no trouble in the forced induction dept.. BUT, unless the compression is lowered in one form or another, high boost levels will be impossible on pump gas.. race gas is a whole different ball game .. BTW, if anyone is worried about the engines reliability.. just think of it this way.. all of hondas current engines are pretty high strung..and none of them break.. do you think they would put a POS in any of their cars? SledgehammerVette 02-09-2001, 08:25 PM This car simply flat out rules! My older bro owns one (white/red) and it is an amazing car. That sweet exhaust note when you hit past 6 grand, redline it at 9K, it is just a very sweet car! The handling is subperb and the high rpms from 3rd gear on throws you back into your seat because of VTEC kicking in! If I was going to look at a $30K car and it had to be convertible this is the car I would take. I have had some great experiences in this car from going over the same hill at 80MPH and passing what looked like a cop car (Caprice(sp?), this was at night) and he downshifted and floored it and then we turned off the road. It gets your blood moving when you get these kinds of scary things like cops going by you when you are doing 80 on a 40MPH road. Highest speed we got it up to was about 120MPH before we came to the stop light. It is just simply a SWEET car! Bean Bandit 02-12-2001, 02:02 PM Today I walked along the lake listening to some Hip-Hop (I'm listening to music often and quite loud) when I heard a car rev. It was a S2000 and I have to admit it sounds very nice when it pushes over 7000rpm:) LotusGT1 02-13-2001, 05:32 AM The S2000 is a great car IMO. The nreliability is excellent (as all Honda's) and the engine is a masterpiece. It can kill almost every car in it's pricerange (Boxster, TT, Z3) and it looks stunning. johnny 05-01-2001, 05:57 PM I love the S2000 unconditionally. However, if Honda did decide to up the S2K's displacement by 0.5 litres or more, I wouldn't mind. Hell there's always the Comptech S/C for people who need some more umph. Jay! 05-08-2001, 06:55 AM Honda's engineering expertise lies in building extremely efficient, naturally-aspirated, lower-displacement engines, and in making them ultra-reliable. This is exactly what they've done with the engine in the S2000. You can say all you like that they should increase displacement, turbo- or supercharge, or try something new in general, but you can't say that the S2000's engine, which has the highest power to displacement ratio of any naturally-aspirated engine on Earth, isn't a spectacular piece of automotive engineering. I'm sure there's a ton of cars that could beat an S2K in a drag race, but how many of those same cars could even try to keep up on a road course? Also: Can any car challenge the S2000 for the title of Best Shifter Ever? JD@af 05-08-2001, 06:12 PM I've heard the BMW M5 and Z8 use shifters that give the S2000's a run for its money. johnny 05-15-2001, 05:24 PM True true. But those cars are monstrously expensive. At a base price of just $32,000, the stook is a steal. Not many cars can boast such a thing. Jay! 05-16-2001, 03:45 AM Originally posted by johnny ...the stook is a steal... I realize now that you mean "S" "too" "K," but when I first read it I though you misspelled "stool," like poop. :eek: Needless to say, I was confused. johnny 05-16-2001, 06:07 AM Yeah. Sorry for the confusion. But, yeah, now you know. three_gunn 05-18-2001, 04:30 PM found ya johnny..hehe.:smoker2: johnny 05-19-2001, 01:28 PM Hey there. Did you make your introduction in AF in general? gabedude 05-22-2001, 11:12 AM I've heard alot of people complain about lack of low end tourque. I see the same problem in my Prelude. But to me, its not a problem. A 2.0 litre engine is not going to have alot of tourque in the low rpm range. Face it. If you want tourque, get a Camaro or a Corvette. If you want a great handling Japanese sports car that feels more like a race car, get an S2000. :D enzo@af 05-22-2001, 02:21 PM lack of low end power doesn't mean much to me anyway....if you want to go fast, don't keep your RPMs in the 1000-3000 range...get 'em up near redline! johnny 05-22-2001, 05:19 PM Amen, my brutha. JD@af 05-22-2001, 11:49 PM I agree as well. I have driven the big torque monster V8's, and frankly, I'd prefer to go fast in a smaller displacement engine that builds and builds until near redline your engine is screaming from the power it's laying down. Some of the big displacement enthusiasts forget that many race cars are in fact engineered in the same school of thought as smaller dispalcement-engined street cars, with narrow, high rpm powerbands. You going to tell me they're doing it wrong? And let's not forget that low end torque also hinders a car's practicality as a daily driver in a variety of weather conditions, particularly in rear-wheel drive models, even with the aid of traction control (although admittedly this aids in vehicular stability and control). johnny 05-23-2001, 02:17 AM yes yes... I'd rather drive an F1 car than, say, a top fuel dragster... iroibeirt 03-08-2002, 12:27 PM I recently read the new Honda Tuning magazine, where they actually tested a Comptech S/C on a new s2k...no numbers but just words. They said that they actually recieved more power in the mid and high end, rather than the low end. And truthfully, i think if u want a lil kick in ur s2k, its worth the money. texan 03-08-2002, 10:28 PM Originally posted by iroibeirt I recently read the new Honda Tuning magazine, where they actually tested a Comptech S/C on a new s2k...no numbers but just words. They said that they actually recieved more power in the mid and high end, rather than the low end. And truthfully, i think if u want a lil kick in ur s2k, its worth the money. Well of course, any centrifugal compressor is going to come online at high RPM. The Comptech doesn't really show up to the party until about 6000 RPM. Automotive Network, Inc., Copyright ©2012
