Damn It!CADTECH023 10-16-2003, 05:47 PM My 85 S-10 Has Been Running Like Crap For About A Month Or So. It Seems To Be Missing And Sort Of Intermitintly Jumpy. I Decided To Rebuild The Carb, And Now The Damn Thing Won't Start. If I Spray Some Carb Cleaner Down The Carb And Pulsate The Gas Pedal While Cranking The Engine I Can Get It To Start For A Second, But I Have To Keep Pulsating The Gas Just To Keep It Running Very Poorly. I Know There Is No Problem With The Fuel Pump And I Also Have A New Filter In, Also The Distributer Cap And Rotor Have Been Replaced. Any Ideas???? One More Question...what Should The Air Fuel Mixture Screw Initially Be Set At? I've Heard Between 1 1/2 -- 2 Rotations Open From Being Completely Closed... Is This True? CADTECH023 10-17-2003, 09:40 AM now i'm thinking vaccum leak..... any one had this type of problem before? yesterday i was able to get it started for about three seconds and then it came to a choking halt.... i don't know but it is acting like a simple problem but i just can't figure it out... that's the agrivating part biljim454 09-22-2004, 04:42 AM did u figure it out i got the same problem MSstate 09-22-2004, 12:53 PM Is there fuel in the fuel bowl? Your float valve might be set too low. busa_4 09-22-2004, 06:14 PM you will have to adjust your idle mixture. get a vacuum gauge and hook it up. run the engine and turn the idle mixture screw/s until you get the highest vacuum reading. set your idle speed on the throttle adjustment linkage. make sure you have the float bowl level adjusted properly or you will starve the engine of fuel or flood the engine. check all vacuum lines and make sure they are in the correct place. you should have a vacuum diagram sticker somewhere in the engine compartment. if not, get a manual. check your basic timing with the vacuum advance hose off. that should do it. good luck! BlazerLT 09-23-2004, 12:23 AM LOL, guys, this thread if from October 2003. biljim454 brought it up from hell. Automotive Network, Inc., Copyright ©2012
