a/f ratio gaugelx2luv 12-07-2001, 12:07 PM which wire do i connect the gauge to on the o2 sensor? is it the white wire on the plug before the o2 sensor? also, do i need to solder it on to the wire or do i just connect them? thanks for the help! Rice-Rocketeer 12-07-2001, 12:38 PM Crap I lost all this info I had but yes I believe it was either white or blue or whitle/blue wire. Something like that. And don't go cheap with wires going to the ECU, Solder it. FBP Si 2000 12-08-2001, 01:25 PM Here you go...this is how I did mines, solder the wire also. http://www.hondaracing.ca/installs/airfuel/index.htm lx2luv 12-10-2001, 04:06 PM thanks for the info...i'm going to finish connecting the wires today. jimmyfunk 01-07-2002, 01:01 PM make sure you do not shortcut the hookup, you will damage your O2 sensor....TRUST ME CivicSiRacer 01-08-2002, 08:31 AM Right just tap into the big white wire at the ECu (closest to the seat). Automotive Network, Inc., Copyright ©2012
