overdriveluckystrike 10-14-2003, 12:50 AM I understand what an overdrive is (lower revs, good for highway), but can someone explain if that is the only time i should be using it? Is there more too it? Its the 4th gear right? MioCLK 10-25-2003, 08:15 PM I understand what an overdrive is (lower revs, good for highway), but can someone explain if that is the only time i should be using it? Is there more too it? Its the 4th gear right? over drive means gears with a ratio below 1:1, if a gear ratio is 0.99:1, then that is an over drive gear So both automatics and manual transmission have over drives. As for a 4th spd auto, most of the time over drive is 4th gear, thats what the button is for. On/off, changing from 4th to 3rd. But some cars have both 3rd and 4th (last two gears) in over drive. So they can't use a botton like that, or OD off means only 1st and 2nd gear. What I do is I just leave in drive. My car doesn't have a OD button, and I am too lazy to shift to 4th gear and move it back to 5th (D) between local and highway. I just let the computer take over. Automotive Network, Inc., Copyright ©2012
