maintenance light on TL2000ACK 12-06-2001, 09:16 AM Does anyone know how to reset the maintenance light on a 2000 Acura TL. Your assitance is greatly appreciated. bshaffer 12-28-2001, 09:09 AM To reset the light.... turn your key to the first position, where the radio and dash lights come on but you do not crank engine and hold in the reset button for the odometer for 10 seconds.... The info is in the owners manual.. shurix 02-21-2002, 03:23 PM how do I reset "maintenance required" light on my 2001 TL? thanks cyberenz 05-10-2003, 03:35 PM Press and hold BOTH the Select and the Reset buttons for the trip odometers. While pressing both, turn Ignition Switch to the II position...it's where the the instrument panel lights light up, but before the engine crank position. Keep pressing down both buttons for about 15 seconds or until the Maintenance Required Light extinguishes. When it does, release the buttons, turn ignition switch to the off position, then start the car and the Maint. Light should be out. yworry 06-17-2003, 05:43 PM To reset the maintenance light just put your key in the slot in front of light and it will turn back to green. Automotive Network, Inc., Copyright ©2012
