clutch helpfierobert 10-07-2003, 11:40 AM Iv'e worked all day on this with no luck, my clutch will not fully disengege the master cylinder and slave cylinder were rebult all lines were checked and good. I can pry on the arm as far as i can get it and then pump the clutch and it will disengage but one I let off and push again it wont. any advice whould be help full LoW_KeY 10-09-2003, 11:37 AM Don't mean to take away from this board.. but you may want to try over at http://www.fiero.nl/cgi-bin/fiero/Ultimate.cgi?action=intro might get a faster reply netjunkkie 10-28-2003, 09:25 PM lol sorry so long to post i had same problem the push rod on the clutch by the trany wore out on mine and i put a small socket over it.... worked for me fierobert 10-30-2003, 10:46 AM well i found out that the clutch master cyliner is bad. im going to rebuild it, hopefuly that fixes my problem. i also replaced the slave cylinder and push rod. Automotive Network, Inc., Copyright ©2012
