1st time @ the track
DL72
10-06-2003, 04:00 AM
kinda lazy so here's the link I posted. Had some pretty good runs and met some very cool domestic guys in the process.
http://www.is300.net/modules.php?name=Forums&file=viewtopic&t=13362147
Next time will be boosting at 1 bar and get into the 12's.
94tegRS
10-11-2003, 06:34 PM
1 bar is like 14.7 psi or something like that right?
JekylandHyde
10-13-2003, 08:50 AM
1 bar = 14.5 psi.
A lot of boost controllers do not read BAR. A lot of them read hg/cm3 which is actual 14.2 psi = 1 hg/cm3.
Good runs :) You are already making 12 sec power (your mph is great). The easiest route to 12s for you is traction. You get those 2.3-2.4 60's down to 1.9-2.0 and you will be much closer to 12s. I suspect adding boost will just give you more wheel spin.
Good luck!
danno_SS
10-14-2003, 12:39 AM
Good Runs :iceslolan
A 106 trap is good enough to break into 12s. You need traction! Get some DRs, cut your 60' to 1.9-2.0 and you should see 12.8-13.0.
