Belt replacement questionjlaird 10-05-2003, 11:53 AM Do you have to jack up the front and/or remove any parts to change out the serpentine belt? Looks really tight in there. Mine is a 98 classic. Thanks in advance. 97 silverbullet 10-05-2003, 07:49 PM well I didnt' want to do it cause I figured it'd take a while so I had my mechanic do it and when he did it took him 2 hours and he had to take the wheel well out to get to the belt but I would go to like pepboys and look it up on the books they have like the chiltons, they dont have a book just for the aurora they have one for all cars like 97 and up or something. Just look at that. jlaird 10-05-2003, 08:13 PM Thanks 97Silverbullet. That is very good advice. I subscribed to alldata and found step by step instructions there. It took me about 3 hours and a bunch cussin'. I had to raise the front and then remove the splash guard. Threading the new belt around the tensioner was a bear. Learned a lot in the process, though. Car still runs and no more squeek. Indy8 10-07-2003, 02:40 AM It sounds like you guy's did some unnecessary work. I have a 97 and I changed mine in ten minutes. If you're just changing the belt there is no need to mess with the torque plate or tensioner. Relieve tension, slide belt off p/s pulley and remove. It's tight threading the new one but nothing in the routing requires removal. That's why dealers can advertise this service for $69 belt and labor, and still make money. If it took a pro mechanic more than 30 minutes, he did'nt know the car. mikelebo99 12-01-2003, 03:20 PM Hey Indy8 Did you access the belt from underneath? Mike Indy8 12-01-2003, 05:06 PM You might have to reach underneath to make sure the belt is centered on the crankshaft pulley, but otherwise you can do it all up top. Use a 1/2 inch square ratchet extension(scrap steel,whatever)and insert it into the recessed area on the forward face of the tensioner. Push the belt towards the engine a little, you'll see it. Now pull forward and down towards the headlight, you'll see the belt go slack, just slide it off the top of the power steering pulley and then let the tensioner return. Work the belt off all the other pulley's, then thread the new one on and reverse the operation. Routing guide is either in owner's manual or on underhood sticker. Draw it out on paper if you have to before you start. It's even easier changing the water pump belt, and at $6, it's cheap insurance. mike98c 12-05-2003, 07:11 PM I also have a 98 classic. When i changed mine I used alldata. I removed the wheel and partially removed the splash shield. The 98 has an extra motor mount but it went smoothly except for getting the belt onto the tensioner (tight fit) and twisting the belt After ten minutes I walked away to get some water and came back to try again the belt slipped right onto the pulley . Total time minus the ten minutes was probably less than twenty minutes. jim56 12-05-2003, 09:06 PM If you are changing the belt, dont forget, the water pump has its own belt, on the other side of the engine. Indy8 12-05-2003, 09:44 PM When installing the belt, thread the whole thing on except for the power steering pulley. Smear a little silicon(die-electric)grease on the outer lip of the pulley and then pull down on the tensioner. It should easily slip on. brihoo2k 12-07-2003, 12:20 AM I just went to one of those quickie oil change places today and the nimrod there said i needed the serpinetine belt changed which i agree with him on that one. When he told me that it required removing a motor mount to do it is when i knew he was full of crap. I used to work on cars for a living and could tell that i have forgotten more than that idot knows otherwise he wouldnt be stuck working in a oil change place. Sometimes I wish i was working on cars for living again but machine repair pays better and i have better benifits. Anyways i can see that by using a 1/2" breaker bar or a rachet extension you can release the tension on the tensioner pulley and remove the old belt and replace it with a new one. So i think that it is entirely possible to do it in like ten minutes. It may be a tight squeeze but it can be done mike98c 12-07-2003, 09:59 PM At first glance it looks like the motor mount needs to be disconnected but any one that works on cars for a living should be able to trace the belt and tensioner in a few moments but considering that one of those places had to buy a friend of mine a rebuilt engine because they put the wrong oil filter on I certainly am not suprised. They were lucky it was a Ford ohv 5.0 liter and not a Northstar! zimaad 12-10-2003, 08:39 AM Hey all, I have a 98 with almost 75K on it. I'm about to change all the hoses and belts before I drive it to Texas from Virginia. I got an estimate from a shop and they wanted, go figure, $500 since they "have to remove the motor mount". I think I'll opt to do it myself! Any advice?? I looked at alldata, but looks like I have to pay. From what I've read, it should make it easier to remove the right front wheel and splash guard to get better access and to lube the pulley. Any other advice? Thanks - jjdewd 12-10-2003, 11:49 AM hmmmm I have a noisey pulley too! (think its the A/C) can it be lubed? or only replaced Indy8 12-11-2003, 02:05 AM Belts and hoses take 60-90 minutes with basic hand tools. A/C clutch pulley's can be replaced. zimaad 12-11-2003, 01:05 PM I just changed both my serpentine belt and water pump belt today in less than 2 hours combined. The first 30-45 mins was just jacking it up correctly, taking off the wheel, and looking the thing over. If anyone wants some guidance just let me know (pm, email, or I can post something here). It wasn't nearly as hard as I thought. Just yesterday I had a shop tell me it would be over $400 to get them replaced along with 2 hoses b/c it would take probably 2.5 hours just for the serpentine since they had to remove the engine mount. That's a crock! Anyways...definately doable with basic tools and maneuvering the belt around. KJH 12-14-2004, 10:17 PM I just changed the large serpentine belt on my '95. Hats off to anybody who can thread the belt between the block and tensioner pulley without pulling off the tire and splash guard. Based upon some of the posts I've seen on AF, I think it's possible just not by me. I tried to replace the belt without first removing the tire/splash guard (I'm embarrassed to say for how long) and was unsuccessful. After removing these items, the belt was on in a 1/2 hour. billysandra 05-16-2007, 04:41 PM I just read your post and want to take you up on the info. please send it to louisvillesace@yahoo.com Thanks BNaylor 05-17-2007, 09:01 AM I just read your post and want to take you up on the info. please send it to louisvillesace@yahoo.com Thanks Sorry but please check the date and do not resurrect old threads. Thread closed. POSTING IN CLOSED OR OUTDATED THREADS: If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread. Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread. Automotive Network, Inc., Copyright ©2012
