Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > GMC > Yukon
Old 10-04-2003, 11:01 PM   #1
ConfusedOne
ConfusedOne Normal reputation
Question 94 Yukon radio wiring??
My friend and I tried to figure out how to hook up an aftermarket CD player. We got the factory radio out, but where do you plug the new wiring harness into. Where is the radio connector. I traced the wire down to a long socket under the steering wheel where it plugs in. Also, wheres the antenna wire??? We have the new panel for the radio and the GN wiring harness for the radio.
ConfusedOne is offline   Reply With Quote
Old 11-09-2003, 12:46 AM   #2
carsdegroote
carsdegroote Normal reputation
Post Re: 94 Yukon radio wiring??
On the 1994 GM Trucks as well as some Pontiacs, the radio display (what you see on the dash) is a remote. The master unit which is metal and has fins on it, should have both your power connector and antenna wire. The Antenna will require an adapter as a side note. All this should be found up inside the dash behind the radio - climate controls, and to the upper right of the brake pedal/ steering column.
carsdegroote is offline   Reply With Quote
Bookmarks
Google
Web AF
