94 S10 Heater core replacement?
Jay85
10-04-2003, 12:12 PM
Hi Fellas',can anyone please give me a basic idea how much time and trouble it is to replace the heater core? Would I be better off putting it in the shop,(never did this before)? Thanks for any help. Jay85
frank3624
10-04-2003, 10:19 PM
I have a chevy 97 S10 no heat I changed the thermostat with no luck I noticed there is a temperture control switch on the dash could this be my problem ? or does anyone have any suggestions .
Frank
GMMerlin
10-05-2003, 08:04 AM
You will need to remove the dash on your truck to replace the heater core....
Do a search of the forums and you will find some tips and tricks people have posted.
GMMerlin
10-05-2003, 08:06 AM
Frank
Are the heater hoses getting hot?
If one is warm and the other cold than most likely you have a stopped up heater core.
What is the condition of your cooling system? Any brown sludge in the radiator or overflow tank?
frank3624
10-05-2003, 01:04 PM
Both hoses are Hot out of the manifold and warm at the heater core entry .I have no sludge in the radiator or the resevoir .
Thank you for help any further help would greatly appreciated .
Frank
frank3624
10-08-2003, 07:40 PM
Frank
Thank's for all your help I back flushed the system once did not work so I Back flushed the system again during back flushing I crimped the hose before the tee to force the water through the heater core . I didn't fell like replacing the heater coreI replaced the heater core on my previously 91 S 10 it is not easy & wentttt to the library & discovered I lwould have to take most of the dash apart . Again Thanks
Sincerly ,
Frank Ranieri :)
