engine codes 32, 42clintnovaclaw 10-03-2003, 03:08 PM Hello, I drive a Ply 96 Neon and was wondering if anyone here could help. My engine light recently came on and following the directions on neons.org gave me errors 32 and 42 which are: 32 EGR system failure 42 Fuel pump relay control ckt, Auto shutdown relay control ckt, No ASD relay output voltage at PCM, Fuel level sending unit volts out of range, Fuel level unit No change over miles I was wondering if these are expensive repairs or are they repairs that I can do myself? Thanks very much for any help you can give me, - Wilson specter 10-04-2003, 01:29 PM just a few weeks ago i had code 32 on my 1997 dodge neon and i found out that my EGR valve had to be cleaned, thats all. dont know bout the other one though Kingspawn2King3 11-24-2003, 10:36 PM Some but not all pcms outputs are a negative feed. Check a wiring diagram like in Chilton’s to see if the pcm puts out + or - volts. My Dakota puts out - to control the relays. Automotive Network, Inc., Copyright ©2012
