firewall hole for amp cable???
younglifeunc
09-30-2003, 12:59 PM
where can i run my 4 ga. amp power cable through the firewall on my acura 3.5 rl? there aren't any visible pre-existing holes, and i am not going to drill through the firewall. anybody know where to run this thing through the firewall?
-P
japsez
09-30-2003, 03:33 PM
in my friend's wrx there's a seal between the firewall and the back of the glove compartment (if you get what i'm saying...?). pull it away and you should see something big enough to run your amp power cable through. if that's not the case... then pretend i said nothing at all.
Jetts
09-30-2003, 03:36 PM
in my ranger, i ran the wire thru the door, where all the wires for the speakers and shit in the door go into and then it came out and then under the carpet
caltegracraig
11-04-2003, 04:25 PM
Shine a bright light like a halogen in the engine compartment. Then look inside under your dash. You will see a lot of glimmering little passage ways that you can stuff you cable through.
