GaugeTyTy8383 09-27-2003, 04:16 PM I was wondering, since an integra and a Civic are so similar if you could install an integra Gauge Cluster into a civic with no or minimal difficulty. SilverY2KCivic 09-29-2003, 01:25 AM I was wondering, since an integra and a Civic are so similar if you could install an integra Gauge Cluster into a civic with no or minimal difficulty. Similar in look perhaps, but not in any by shape or size. Do a search, this was touched on a couple weeks ago, the "interior" forum might be a good start to look at. :rolleyes: But basically it'll cost you a lot of time and $$$ to fit one into a Civic since it'll require a bit of custom fabrication of the dash to fit it. That's the long and short of it. 90CRXZCSi 09-29-2003, 02:38 AM it wont fit. Ive had alot of freinds try it before. Even if you did get it to fit, the plugs are not the same in the back of the cluster. TyTy8383 09-29-2003, 05:08 AM What about a newer model Civic, will they Fit and wire into a 95 say for instance from a 2000?? B16EJ1 09-29-2003, 06:31 PM You need the whole dash and I assume the wiring is different. Overall........it's a waste of time. SilverY2KCivic 09-29-2003, 08:52 PM What about a newer model Civic, will they Fit and wire into a 95 say for instance from a 2000?? Nope, still won't fit properly, clusters are different shape, though similar size. Automotive Network, Inc., Copyright ©2012
