94 prizm problems, please read, please help
JasonKnight
09-26-2003, 06:52 PM
i have a 1994 geo prizm that is running rich and stumbles on acceleration. feels like a lack of fuel is getting to the engine. jets checked, plugs checked, filters checked, cat checked. doesn’t pick up at all, 2nd gear acceleration jumps, idles ruff, bluish black smoke from exhaust. all out of ideas, need some help.
JasonKnight
09-26-2003, 09:53 PM
more info
runs rich, all 4 plugs have black, dry, carbon buildup.
please help
bathouses
01-15-2004, 11:54 AM
I'm looking for a prizm to buy. I have a 90 parts car that runs good with body damage and rust. chicago area
1995 geo tracker
01-16-2004, 03:00 AM
check the compression of each cylinder and see if they are close to each other , sounds like you might have a burnt valve , also is the check engine light on?
stephiemullen
12-26-2004, 05:29 PM
I have that problem with my 95 prizm. If I don't warm up the car before I drive, it kinda hesitates in 2nd gear for a minute and then its fine. I have had the engine rebuilt twice. Once for piston rings, and the second for oil burning and a burnt valve. I am starting to give up.
stephiemullen
01-07-2005, 05:01 PM
Sounds like you may have bad piston rings and other internal parts. Have you checked your O2 sensor? If you are blowing bluish smoke, that means you are burning oil, and that is a bad sign! Go get a block test and compression test. It really sounds like you need an overhaul like mine did. Good luck. Let me know the followups.
It is a car!
02-10-2005, 12:28 PM
the blue smoke is the key- burning oil.
lifeseed
02-10-2005, 09:28 PM
Installing alternator belt, How do I loosen gthe a/c belt on my 95 geo metro inorder to install alternator belt? On my third
