Add VTEC to an LS?DJSublime87 09-26-2003, 04:33 PM Is there any way to add VTEC to an 1995 Integra LS? How much would it cost, and is it practical or just dumb? 94tegRS 09-26-2003, 05:50 PM well, since the search thing never works for me ill tell you, and not just say search LSVTEC, but you a VTEC head/ECU/harness and youll need about 100 dollars worth of fittings/oil lines, either drill the head for bigger dowel pins or get the ones that are dual sized for no drilling, plug old oil supply, run oil line to the plugged supply on back of head, enlarge head gasket dowel holes, bolt it together, run wiring. youll also need a knock sensor as well as a crank flux sensor i think, it isnt quite as easy as I made it sound but if you gather all the knowledge/parts before you start it shouldnt be too much trouble. Automotive Network, Inc., Copyright ©2012
