air intake question
SkylinesKillAll
04-03-2001, 09:08 PM
ok first of all i have a 93.5 g20. when i went to nopi it showed that they have an air intake for 95-99. would that fit in my engie? im sure i could move some stuff around if i had to or did they move the air box after 94? any help would be appreciated
Koojo
04-03-2001, 10:27 PM
You can get a K&N filter. they are for 91-96 g20's. Those are the best filters.
ni55andriven
04-03-2001, 10:42 PM
I have the Weapon-R intake..also from Nopi. I dont really know how the 93.5 G20 engine looks but it still is an SR20DE so i dont see why it shouldnt fit. Someone mentioned in another post that the air sensor of the 2000 G20 was larger than the 1999 (did i get that right?), which is why an intake from a '99 wont fit a '00. I suppose if the air sensor is the same size of the '99 then itll fit. You could also just get rid of the stock airbox and just put on a cone filter from Stillen of Jim Wolf Technology. The Weapon-R just comes with a colored tube to replace the stock rubber one. Hot Shot (www.hotshot.com) makes a complete cold air intake system for the 91-93 G20 and also the 94-99 G20 for $201. That might be better performancewise. And maybe (?) you can add the AEM water bypass valve on the cold air if you live in a damp/moist area just to be safe. Oh yeah, I changed the Weapon-R filter to a different one. It was made of foam and I wanted something a little different. I dont think it matters anyway. Hope this helps. :smoker2:
SkylinesKillAll
04-03-2001, 10:49 PM
thanx alot. thats exactly what i was lookin for. i appreciate it. :sun:
LCDinmyG20
04-03-2001, 11:40 PM
Does DEQ allow the use of this aftermarket intake ? Or do you guys just remove the high performance intake and replace it with the stock air box before you go through emissions ? I want to purchase one also but swapping it in and out seems like a pain in the ass. :eek:
thanks
I've had my G20 for two days and I love it!
b-b00gie
04-03-2001, 11:55 PM
state inspections vary a bit. i live in new jersey, and they do not check anything under your hood. i dont think having an aftermarket airfilter or intake would affect your emissions test. all it does is suck more air in especially at higher rpm's. in new jersey the emissions test is done while the car is idle, so basically the aftermarket unit isnt really doing much at that point. =)
GtRider
04-10-2001, 04:17 PM
dude if you lookin for an intake for a 1993 g20 just buy the filter and the adapter!! it'll cost you no more than 50.00...
i own a 1994 g20t and it has a custom cold air intake!!
thats rite its custom!!! all you have to do is go to a muffler place and let them bend you a 3' pipe from under the fender all the way to the adapter and just let them torch the 2 peices together THEN PUT THE FILTER ON THE BOTTOM!!! BAM A CUSTOM MADE COLD AIR INTAKE!!!!
Koojo
04-10-2001, 06:25 PM
is that all that the air intake is? a tube and a filter? so the only reason that they dont sell many intakes for our cars is because the tubes arent bent to fit our cars? so can u get a good filter, add it to a custom tube, and connect it to the adapter? on my p11, there are all these wires and metal things coming out of the plastic tube . whats up with that
LCDinmyG20
04-11-2001, 12:12 AM
GtRider,
What brand and model number did you use for the filter and adapter?
How low from the ground did you extend the pipe ?
Thanks for the great idea. :cyclops:
G-Forces
04-11-2001, 10:13 AM
Here guys here's some things to consider...
http://www.se-r.net/engine/about_intakes.html
dchien
04-25-2001, 05:32 PM
hey is the adapter really necessary? does it really give you more horses because you move the filter to a colder area of the engine?
what is every one using as a air filter, k&N? what do people recommend and how much is it?
thanks in advance
d
:flash: :monkeypis :badass:
Koojo
04-25-2001, 09:58 PM
K&N are really good filters, but they dont make them for '00+ . You might get it custom installed but not from factory. They will cost you around 40 bucks i think....but they last for a LONG time...you just have to clean them out once in a while with a special cleaning product that K&N makes
SkylinesKillAll
04-25-2001, 11:27 PM
hey guys i was jus readin the hotshot website and it said the intake isnt meant for wet weather so if it rains does it mean i should put the old airbox back in? :confused:
ni55andriven
04-26-2001, 01:17 AM
No, I don't think so. I don't see why you wouldnt be able to put on the AEM air bypass valve. I saw in the ultra performance catalogue for $44.95...3 sizes too.
G-Forces
04-26-2001, 10:27 AM
I think they say that to cover their asses. If you drive through a huge puddle and hydrolock your motor you can't sue them. Kind of like an 'I told you so.'
Nismoboy1
04-26-2001, 10:33 AM
I ran a Place Racing CAI on my old Sentra for almost 2 years in all sorts of weather and I never ran into a problem with my intake or my engine hydrolocking but to be on the safe side I'd get the AEM bypass valve also, from what I hear it's very effective :cyclops:
dchien
04-26-2001, 06:29 PM
what is the model number for the k&n filter. Is everyone using the piping? does it really make that much difference if i do use the piping? if i don't use the pipe, will it have any increase in hp over the stock?
thanks in advance
D
:badass:
kris
04-26-2001, 07:31 PM
I don't know how true it is but I heard even the 3" Bypass Valve is too small for the Place CAi. It is a tight fit that will likely break the plastic part of the bypass valve. I have seen one but never touched one. This is what I have heard from people who have tried it with a Place racing Intake. The O.D of the Place racing tubes is slightly larger than the AEM 3" bypass valve.
Like I said, this is not first hand knoweledge, just what I was told by someone locally.
Nismoboy1
04-27-2001, 09:51 AM
wow...thats the first i've heard of this, it would be pretty interesting if someone here tried it out and see if this true, too bad place racing doesn't make jack for my car...:bathroom:
